Masso G3 Controllers
Manual Mode Operation
Wiring your Spindle to Masso G3 Controller for Automatic Mode Operation
Preparing Controller for Wiring
Your control cable will include a special Spindle Inlet Cable which you can use to wire up your G3 Touch controller.   Attaching this inlet cable is relatively easy and we go into detail here:  https://support.pwncnc.com/kb/article/336-spindle-inlet-cable-and-masso/
However here are  the highlights:
Black => GND
Shield Drain => GND
Red => Pin 1
White => Pin 4 & 6
Yellow => Pin 5
Green => Pin 7
Orange => Tape-off as it is unused.
Use a jumper wire (not provided) to link Pins 4 and 6 together.
The orange wire supplies 10v power and is not required by the Masso G3.
Spindle System Wiring
Spindle Kit Wiring
This mode is where your CNC controller controls the VFD via a simple PWM variable voltage signal.  For Masso G3 this is 0-10v representing 0-24000rpms.
We have pre-programmed your VFD to run in automatic mode when the Manual Override switch is flipped to automatic (down or 0 position).  The vfd will monitor the PWM (red wire) and GND (black wire) for how fast the controller is instructing the VFD to spin the spindle motor.  You must still hit the "RUN" button on the VFD's keypad to change the vfd from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
P0.0.03 = 1
P0.0.04 = 3
Your Masso G3 is capable of triggering an internal relay which activates the Run/CW/Forward functionality of our VFD via the Yellow and White wires.
When your VFD switches to Run Mode the vfd will change from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
Setting up your Masso G3 Controller for Automatic Mode Operation
We have played with Masso G3 controllers before and here are a few notes we've gathered as to how to configure it for controlling a spindle:
From the Masso’s main user interface, go to the “F1 Setup” tab and double-tap “Main Spindle”. Then enter the following information: Encoder: 100, Spindle Control Method: VFD, Maximum RPMs: 24000, Spin UP: 6000, and Spin DOWN: 6000.
Then hit OK and return to the “F2 Program & MDI” screen for testing/validation.
With your manual override button on the VFD down, pressing the blank space next to Spindle CW and typing 6000, then pressing Spindle CW, will turn the Spindle on at 6000 RPM.
You can also go into the MDI dialog your by pressing the MDI button in the lower right and typing M36000. M5 will turn it off.
To test for Automatic control put an RPM in the blank box of the F2 Screen and hit Spindle CW/CCW
