Manual Mode Operation
Spindle Systems have a convenient switch on the side of our enclosure which lets you switch between "Manual Mode" and "Automatic Mode". When flipped to manual (up or 1 position) you can hit the run button on the VFD's keypad and turn the dial controlling the motor just like you would a palm router.
See more: https://support.pwncnc.com/kb/article/658-phase-2-manual-mode-operation/
Spindle Kits come programmed for immediate use in "Manual Mode". This means you hit the run button and turn the dial to start your spindle motor just like you would a palm router.
See more: https://support.pwncnc.com/kb/article/655-phase-2-manual-mode-operation/
Wiring your Spindle to NightHawk Controller for Automatic Mode Operation
Spindle System Wiring
See more: https://support.pwncnc.com/kb/article/659-phase-3-controller-wiring-and-automatic-control/
Spindle Kit Wiring
See more: https://support.pwncnc.com/kb/article/656-phase-3-controller-wiring-and-automatic-control/
If you have our spindle kit, then you'll be digging into the VFD directly to wire it up. Connect it as shown below:
This mode is where your CNC controller controls the VFD via a simple PWM variable voltage signal. For NightHawk Controllers this is 0-10v representing 0-24000rpms.
We have pre-programmed your VFD to run in automatic mode when the Manual Override switch is flipped to automatic (down or 0 position). The vfd will monitor the control cable for how fast the controller is instructing the VFD to spin the spindle motor.
The Controller can control the CW/Forward function via the White & Yellow wires while the CCW/Reverse function via the White & Green wires.
Our spindle kits do not come with a vfd enclosure and as such you're expected to provide that as well as properly wiring up the high-voltage electrical. If unsure, consult an electrician.
Learn how to navigate your VFD programming here: https://support.pwncnc.com/kb/article/664-how-to-program-your-vfd/
P0.0.03 = 1
P0.0.04 = 3
It will also monitor the other wires to know if it should switch from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display with FWD led lit up) or spin/reverse mode (solid keypad with FWD led not lit up).
Setting up your NightHawk Controller for Automatic Mode Operation
We're experts in our VFD and spindles, but not experts in your particular CNC Controller. If you have specific questions, we will encourage you to seek advice and guidance from your machine provider.
We have not played with the NightHawk controllers before so no one has confirmed this information beyond what their controller manual includes.
