Avid Controllers
Manual Mode Operation
Wiring your Spindle to Avid Controller for Automatic Mode Operation
Spindle System Wiring
Spindle Kit Wiring
This mode is where your CNC controller controls the VFD via a simple PWM variable voltage signal.  For Avid this is 0-10v representing 0-24000rpms.
We have pre-programmed your VFD to run in automatic mode when the Manual Override switch is flipped to automatic (down or 0 position).  The vfd will monitor the PWM (red wire) and GND (black wire) for how fast the controller is instructing the VFD to spin the spindle motor.  You must still hit the "RUN" button on the VFD's keypad to change the vfd from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
P0.0.03 = 1
P0.0.04 = 3
Your Avid is capable of triggering an internal relay which activates the Run/CW/Forward functionality of our VFD via the Yellow and White wires.
When your VFD switches to Run Mode the vfd will change from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
Setting up your Avid Controller for Automatic Mode Operation
We have played with Avid controllers and Mach3 before and here are a few notes we've gathered as to how to configure gSender for controlling a spindle:
Open Mach4 and ensure your machine is “disabled”. Under Configure, open the Avid CNC Mach4 Configuration. Within this screen you’ll need to configure the “Spindle Type” value to 3HP Avid CNC Spindle then hit “Save”
In Avid CNC Mach 4 Configuration under the General tab, select cutting tool: Spindle, and 3HP Avid CNC Spindle and hit save.
Under the MDI screen you can check that automatic control is working by typing m3s6000. Your spindle should spin up to 6000 RPM, and then M5 to stop.
Quick_Start_Guide_-_AVID.pdf
