Home > Spindles & ATCs > Controller Guides for Automatic Control > Sienci Labs - LongBoard Controllers (aka LongMill's)
Manual Mode Operation
Wiring your Spindle to Longboard for Automatic Mode Operation
Spindle System Wiring
Spindle Kit Wiring
This mode is where your CNC controller controls the VFD via a simple PWM variable voltage signal.  For Longboards this is 0-5v representing 0-24000rpms.
We have pre-programmed your VFD to run in automatic mode when the Manual Override switch is flipped to automatic (down or 0 position).  The vfd will monitor the PWM (red wire) and GND (black wire) for how fast the controller is instructing the VFD to spin the spindle motor.  You must still hit the "RUN" button on the VFD's keypad to change the vfd from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
P0.0.04 = 3
P2.0.15 = 05.00
However you must still hit the "RUN" button on the VFD's keypad to change the vfd from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
Setting up your Longboard Controller for Automatic Mode Operation
We have played with LongBoard controllers before and here are a few notes we've gathered as to how to configure gSender for controlling a spindle:
Configure your gSender appropriately.  For more information see https://sienci.com/2022/07/21/adding-a-spindle-to-your-longmill/
$16=Spindle Enable
$30 = 24000
$31=6000
$32 = 0
$395=MODVFD
$462=40960
$463=40961
$464=36864
$465=1
$466=2
$467=5
$468=25
3 out of 3 found this helpful
Quick_Start_Guide_-_Sienci_Labs_Longboard.pdf
