Installing Homing Switches
The X homing switch is installed onto the X carriage and travels with it.  It is mounted to a 3d printed base-plate which allows you to adjust the sensor left or right as needed.
Installing the X homing switch is installed using a few screws through the horizontal X plate.
Run the wire up through the large circular hole in the middle of the plate and let it sit for a later step.
The Y homing switches are mounted onto each side of the gantry and travels with it.
The Z homing switch is mounted over the right shoulder of your Z-Carriage.  It is attached with two screws:
