All tube bundles are made of 6 components.
- The Boot (V2 or V3)
- PwnCNC Extension Adapters - A simple screw-together 90 or 45deg adapter.
- The Tube - See-through vertical tube to reposition the hose intake at the top-rear of your X/Z Carriage.
- Z-Independent Bracket systems - Customized to fit a variety of machines, this bracketing system mounts onto your machine and provides the z-independent boot a vertical track for mounting onto.
- Ultimate Hose Clamps - Highly modular hose mounting system that has a variety of attachments to the machine, reaching out to hold the hose or in this case our Tube.
- Maglock Round Adapter (instructions included here)
Assembling the Base, Arm and Tube Clamp
These last 2 screws replace the screws on the back of the Z Stepper motor and give our stepper base a place to be secured.
The Tube Extension Adapters Assembly, and maglock assembly (requires an adheisive like super glue)
