All tube bundles are made of 6 components.
- The Boot (V2 or V3)
- PwnCNC Extension Adapters - A simple screw-together 90 or 45deg adapter.
- The Tube - See-through vertical tube to reposition the hose intake at the top-rear of your X/Z Carriage.
- Z-Independent Bracket systems - Customized to fit a variety of machines, this bracketing system mounts onto your machine and provides the z-independent boot a vertical track for mounting onto.
- Ultimate Hose Clamps - Highly modular hose mounting system that has a variety of attachments to the machine, reaching out to hold the hose or in this case our Tube.
- Maglock Round Adapter (instructions included here)
Here are pictures of how your Shapeoko 3 Tube Bundle is assembled.
Note your Z Independent Brackets may diff based on which Z Independent Axis you have.
Assembling the Stepper motor base, Arm and clamp
The Screws mount to the stepper motor.
Assembling the Tube, Maglock fittings and Extension Adapter (your configuration with the extension adapter may differ based on circumstances.
