Home > Dust Collection > Dust Boots > Tube Bundles Assembly > Tube Bundle for Upgraded X-Carve
All tube bundles are made of 6 components.
  1. The Boot (V2 or V3)
  2. PwnCNC Extension Adapters - A simple screw-together 90 or 45deg adapter.
  3. The Tube - See-through vertical tube to reposition the hose intake at the top-rear of your X/Z Carriage.
  4. Z-Independent Bracket systems - Customized to fit a variety of machines, this bracketing system mounts onto your machine and provides the z-independent boot a vertical track for mounting onto.
  5. Ultimate Hose Clamps - Highly modular hose mounting system that has a variety of attachments to the machine, reaching out to hold the hose or in this case our Tube.
  6. Maglock Round Adapter (instructions included here)
Here are pictures of how your Upgraded X-Carve Tube Bundle is assembled:
Assembling the base, Arm and Tube Clamp
The Tube, Extension Adapter, and magring/round assembly *requires adhesive
v3.pdf v2.pdf
