Tube Bundle for New Carve
All tube bundles are made of 6 components.
  1. The Boot (V2 or V3)
  2. PwnCNC Extension Adapters - A simple screw-together 90 or 45deg adapter.
  3. The Tube - See-through vertical tube to reposition the hose intake at the top-rear of your X/Z Carriage.
  4. Z-Independent Bracket systems - Customized to fit a variety of machines, this bracketing system mounts onto your machine and provides the z-independent boot a vertical track for mounting onto.
  5. Ultimate Hose Clamps - Highly modular hose mounting system that has a variety of attachments to the machine, reaching out to hold the hose or in this case our Tube.
  6. Maglock Round Adapter (instructions included here)
Here are pictures of how your New Carve Tube Bundle is assembled:
Overall of how it'll look when done.
Assembly of the Stepper Base, Arm, and Tube Clamp
These screws attach the whole assembly to your Nema Stepper motor
Assembly of the tube and extension adapters.
*Your configuration may differ based on machine considerations.
v3.pdf v2.pdf
