Home > Spindles & ATCs > Misc > Why We Use 18 AWG Wire in Our Spindles
At PwnCNC, we’ve carefully selected each component in our spindle kits to balance performance, safety, flexibility, and ease of installation. One common question we receive is:
"Why does the spindle cable use 18 AWG wire instead of something larger like 16 or 14 AWG?"
Below, we’ll explain the reasoning behind this decision, based on electrical safety standards, practical usage, and field experience.
Electrical Load and Wire Rating
Our spindle kits operate at 220V with a maximum current draw of 10 amps. According to common electrical standards:
  • 18 AWG copper wire can safely handle up to 16 amps in free air and around 10–13 amps in cable bundles, depending on insulation and environment.
  • Since spindle cables are typically under 20 feet long, voltage drop is minimal and well within tolerance.
Moreover, spindles rarely operate at full 10-12A continuously. Typical real-world current draw for a 2.2kW spindle is 6–8A, especially under typical cutting loads.
High-Quality Cable Construction
We don’t use generic 18 AWG wire. The cable included in our spindle kits features:
  • High-temperature insulation (rated to 80–105°C),
  • Voltage insulation typically rated at 300V or more, and
  • Shielding to reduce electromagnetic interference (EMI) caused by high-frequency switching from the VFD (variable frequency drive).  These are a physically shielded cable. For optimal EMI performance, the shield must be grounded properly at the controller or VFD end.
Mechanical Considerations
  • Flexibility: 18 AWG wire offers superior flexibility compared to thicker gauges like 14 or 12 AWG. This makes routing the cable through drag chains, loops, or tight corners easier without adding strain to connectors or the spindle’s cable gland.
  • Weight and Stress: Thicker wire adds bulk and stiffness, which can fatigue over time or put unnecessary stress on connectors, especially in moving cable applications.
Safety and Protections
All kits are designed with proper safety measures:
  • The VFD can be configured with a current limit, ensuring the spindle cannot exceed the rated draw under normal conditions.
This means the cable is never expected to carry more current than it is rated for, even during heavy cuts or tool changes.
Can I Use a Larger Wire Gauge?
Yes. If your specific setup involves:
  • Cable runs longer than 20 feet,
  • High ambient temperatures, or
  • Full-power, continuous-duty cycle use,
    then you may benefit from upgrading to 16 AWG wire.
We're happy to provide recommendations or discuss your setup if you have questions.
Summary
Feature Why 18 AWG Works
Electrical Load Safely supports 10A at 220V over short runs
Cable Quality High-temp insulation, shielding for EMI
Flexibility Easier to route and less stress on components
Standards-Based Meets industry safety and performance norms
Upgradable Optional 16 AWG available for custom needs
If you have any doubts or unique installation needs, reach out to our support team. We’ll make sure you get a spindle setup that’s safe, reliable, and suited to your machine.
