Here is an overview of the bagged parts included with your Tube-Bundle. Later in this article we'll break each baggy down.
In general bracketing will require assembly onto your machine. See the following:
Shapeoko 4's with HDZ Upgrade: https://support.pwncnc.com/kb/article/52-bracketing-for-shapeoko-4-w-hdz/
Shapeoko Pro's with HDZ Upgrade: https://support.pwncnc.com/kb/article/54-bracketing-for-shapeoko-pro-w-hdz/
v3 Dust Boot
Note your boot will need assembly. Instructions found here.
Bracketing Plastics for Shapeoko 4 & Pro with upgraded HDZ
Bracketing Screws also for Shapeoko 4 & Pro with upgraded HDZ
Aluminum Brackets
Thumb Screws
Bracketing Arms
Ultimate Hose Clamp with Stepper Base, XL Arm, and Tube Attachment
Extension Adapter with both 45deg and 90deg elbows
The Tube & Round Adapter
Note that you'll need to super glue the adapter on one end of the tube, and one of the two included MagRings to the other.
The second MagRing will be glued onto the MagRound adapter.
