🛠 Tool-Setter – Quick Start Guide
Thank you for choosing a PwnCNC Tool-Setter!
Here are a few important things to know before installation:
- This universal tool-setter works with a wide range of CNC machines and controllers.
- It's pre-configured for plug-and-play use with all PwnCNC Machines and Conversion Kits.
- The unit includes a GX12 4-pin female cable connector for quick and easy setup.
Note:
Some units may include an unsoldered male panel connector pre-attached to the cable.
- If you're using a PwnCNC system (machine or conversion kit), you can disregard this part.
- If you're using a non-PwnCNC system, you can either solder wires onto the included connector for use with your setup or purchase our ready-to-use inlet cable here:
👉 pwncnc.com/products/cable-inlet
