XYZ Block Holder
The Probe Block Holder is specially designed to hold your probe block when not in use, featuring a slotted hole at the bottom to allow any debris that may get caught in there out.
Information on the XYZ Block for Masso can be found here
Installing is super easy as you first decide where to put it, then drill a hole for the screws, and put the holder together.
Figure out where you will be mounting it.
With your holes predrilled screw the screws into place.
Illustration of screws in place.
Illustration of probe block in place.
Highlighting the Slotted hole for debris.
