Home > Spindles & ATCs > Misc > Spindle Mount and Adapter Plate
Our spindle mount system is designed in two parts:
  1. A common spindle mount clamp, available for either 65mm or 80mm spindles.
  2. An adapter plate, which either replaces your machine’s Z-plate or attaches directly to it.
The first step is to verify that you have the correct adapter plate for your CNC model. Each machine requires a slightly different mounting method, so our plates are engineered to match those variations.
Keep in mind that designs may evolve over time. The plate you receive may look slightly different than the reference images below—but rest assured, the mounting hole patterns and machine compatibility remain unchanged.
Custom Plates Available
If your CNC machine isn’t listed below, don’t worry—we can help. Our team can design and manufacture a custom adapter plate tailored to your specific machine. This ensures you’ll still be able to securely mount and use our spindle system with confidence.
👉 Contact our support team with your machine details, and we’ll work with you to create the right solution.
or best results, we strongly recommend applying blue Loctite to all screws during installation. This helps prevent hardware from loosening due to vibration while carving.
Mega-V(1)
(2) M5x20mm Button Screws
(2) M5 Lock Nuts
Attaching directly to the stock Z plate.
Mega-V2
(4) M5x20mm Button Screws
(2) M5 Lock Nuts
Shapeoko 5 Pro
(4) M6x12mm Socket Screws
Screwed directly into the stock Z plate.
LongMill MK1
Reusing existing hardware and completely replacing the MK1's steel Z plate.
LongMill MK2
Reusing existing hardware and completely replacing MK2's steel Z plate
StepCraft
You'll be reusing the t-track nuts from your original mount along with the included M6x12 Socket screws.
Workbee
(4) M5x15mm Button Screws
Reusing (2) M5 T-Track nuts that came with your workbee.
Attaching directly to the Z extrusion.
i2R
This plate has 70mm spaced mounting holes to attach to i2R's t-track mounting system.
* Keep in mind that your adapter plate may have extra holes beyond those shown above. These are intentional, as some plates are designed to fit multiple machine models.
* There are more drawings attached to this KB article than described above.  We have designed many adapter plates including many custom plates for unique machines.  If you are trying to figure out which plate fits your machine best, please refer to the attached drawings and reach out to us at [email protected] with questions.
Secure the plate firmly using the specified hardware. If your machine’s original hardware isn’t being reused, we’ll supply the necessary fasteners with your order.
On every adapter plate designed above... there will be 4 threaded holes to receive our spindle mount's M6x80mm screws.
The second step is to install the left two M6x80mm bolts, the spindle motor, and the other two M6x80mm bolts.
Bonus:  Use the included M5x25mm screw to expand the diameter if you’re having trouble installing your spindle motor.  But don’t leave the screw after installation is complete.
Another bonus:  We’ve added a variety of M5 screw holes for adding accessories around your spindle mount.
Checkout our KB article for additional information and stay tuned for accessories coming to our store soon.
2 out of 2 found this helpful
SM-AP-4.pdf SM-AP-i2r.pdf SM-AP-M1.pdf SM-AP-M2.pdf SM-AP-M3.pdf SM-AP-MK1.pdf SM-AP-MK2.pdf SM-AP-MV1.pdf SM-AP-MV2.pdf SM-AP-S5P.pdf SM-AP-SC.pdf SM-AP-WB.pdf Spindle_Mount_Drawing.pdf SM-AP-5.pdf
