Home > Dust Boots > Choosing the Perfect Dust Boot > Dust Boots for Onefinity w/ Z20
  • Z-Independent boots hover over your stock allowing your 65/69mm Palm Router (or even our 65mm or 80mm Spindle Motor) to move freely in the Z direction.  These types of boots are perfect for 2.5d carving like simple signs but can also be utilized for 3d carving if certain requirements are satisfied, more on this later.
  • Spindle / Router mounted boots attach directly to your Spindle or Palm Router and moves in the Z direction.  These types of boots are perfect for 3d carving.
Is Z-Independent Bracketing Required?  Yes... you will need bracketing with your Z-Independent dust boot (V3V8V9).  Bracketing is used to mount the boot directly onto the X carriage avoiding contact with the Z that is moving up/down.  We have the perfect z-independent bracketing system for your Onefinity w/ Z20 regardless of which spindle/router your using:  65mm or 80mm.
Front or Rear Loading
  • Rear Loading (our v3/v9 designs) gives you the greatest visibility and access to your router, but these features come at a cost... reduced Z capacity.  The boot itself has been optimized to take as little of your machines Z capacity as possible... roughly 1.75".  But for today's modern hobby CNC machines that isn't really a problem since most have capacities upwards of 6".  This means you can easily carve 3/4" or even 2-3" thick stock and our rear loading dust boot designs.
  • Alternatively, our v10 design offers a Spindle/Router Mounted boot that also takes up no Z capacity and will work great no matter which configuration your Onefinity w/ Z20 is in.
  • Note the V7 will only work in only 1 configuration with the Z20. A 65mm router or spindle in an 80mm mount using a shim. No other configuration will work due to restricted clearance on the back side.
4 out of 6 found this helpful
