Home > Spindles & ATCs > B. Mechanical Install > 3. Cable Routing & Strain Relief
(Protecting Your Spindle System from Early Failure)
Most spindle failures are not electrical.
They are mechanical cable failures.
High-speed spindles combined with moving CNC axes create constant motion, flexing, and vibration. If cables are not routed correctly, they will eventually fail.
This article focuses strictly on mechanical routing and strain relief.
Grounding specifics are covered in the Power & Grounding section.
Why Cable Routing Matters
Your spindle system relies on:
  • High-current motor power cables
  • Signal/control cables
  • (ATC only) pneumatic lines
If these are:
  • Bent too tightly
  • Pinched in drag chains
  • Allowed to rub against metal
  • Unsupported near the spindle
…you will eventually experience:
  • Intermittent faults
  • Random shutdowns
  • Under-voltage errors
  • Communication loss
  • VFD protection trips
Most of these begin as small internal conductor breaks that worsen over time.
1️⃣ Drag Chain Routing Principles
Drag chains exist to protect cables from uncontrolled motion.
They do not protect against poor routing.
Follow these rules:
✔ Maintain Proper Bend Radius
Cables should curve naturally inside the chain.
They should never:
  • Be sharply folded
  • Be forced into tight corners
  • Be compressed against the chain wall
If the chain closes tightly around the cable, it is too full.
📷 Photo Suggestion:
Properly routed drag chain showing gentle cable curves vs overly packed chain.
✔ Do Not Overfill the Chain
A drag chain should never be packed full.
Cables must have:
  • Slight freedom of movement
  • Separation from sharp edges
  • No compression when chain flexes
Overfilled chains create internal friction and early conductor fatigue.
✔ Separate High Power from Signal When Possible
While shielding helps electrically, mechanically you should:
  • Avoid tightly bundling motor power cables with delicate signal wires.
  • Allow slight spacing where possible.
This reduces friction and wear.
2️⃣ Avoiding Pinch Points
Inspect the full axis travel.
Look for:
  • Cable contact with frame edges
  • Contact with gantry uprights
  • Points where cable bends sharply during full extension
  • Compression when Z is fully lowered
Cycle each axis slowly by hand before powering the machine.
Watch the cables.
If they move abruptly, tighten, or rub, correct it before proceeding.
3️⃣ Preventing Z-Gantry Rub-Through
One of the most common failures:
The spindle cable rubbing against the Z gantry or mount during vertical travel.
This happens when:
  • The cable exits the spindle and immediately bends backward
  • There is no strain relief
  • The cable rests against metal during motion
Over time, insulation wears away.
This can lead to:
  • Short circuits
  • Under-voltage faults
  • Hard VFD trips
  • Severe damage
✔ Proper Exit Direction
The spindle cable should:
  • Exit straight upward initially
  • Be supported before bending toward the drag chain
  • Never sharply bend at the connector
📷 Photo Suggestion:
Correct vertical exit with gradual bend vs sharp immediate backward bend.
4️⃣ Strain Relief at the Spindle Body
The connector at the spindle is not a structural support.
It is an electrical interface.
Do not allow:
  • Cable weight to hang directly from the connector
  • Drag chain tension to pull against the connector
  • Lateral force on the plug
Use:
  • Zip ties
  • Printed brackets
  • Clamp blocks
  • Soft strain relief loops
The goal is to support the cable within 2–4 inches of the spindle body.
5️⃣ ATC-Specific Routing Considerations
(ATC Systems Only)
In addition to power cables, ATC systems include:
  • Air lines
  • Sensor cables
These must be:
  • Routed separately from sharp frame edges
  • Protected from tool rack interference
  • Allowed enough slack for tool change height
Never allow air lines to kink during full Z travel.
6️⃣ Common Failure Patterns
Recognizing early signs prevents major damage.
Watch for:
  • VFD faults when gantry reaches one side
  • Errors triggered by bumping the cable
  • Inconsistent spindle speed
  • Faults during plunges
  • Visible insulation wear
If moving the cable causes a fault, stop immediately.
This is almost always internal conductor fatigue.
Continuing to run in this state can damage the VFD output stage.
7️⃣ Cable Inspection Checklist
Before first power-on:
  • ✔ No tight bends
  • ✔ No rubbing against metal
  • ✔ No tension at full axis travel
  • ✔ Connector fully seated
  • ✔ Drag chain not overfilled
  • ✔ Z axis tested through full travel
After installation, inspect cables periodically.
CNC machines vibrate more than most users expect.
Important Distinction
Mechanical routing protects:
  • The physical integrity of the cable
  • The longevity of your system
Electrical grounding and shielding termination are covered separately in:
Power & Grounding
Before Moving On
Once your cables:
  • Are properly routed
  • Have correct strain relief
  • Move freely through full axis travel
You may proceed to:
Power & Grounding
Take your time here.
Cable routing mistakes are rarely immediate — they fail months later.
Correct routing now prevents expensive problems later.
