Before installing anything, take a few minutes to verify what you received.
This article covers all PwnCNC spindle products in one place. Depending on what you purchased, some items will differ slightly. Look for the callout sections below that match your order:
Spindle Kit
Spindle System
ATC System
If anything appears missing or damaged, contact us before proceeding with installation.
Shared Components (Included With All Systems)
Every PwnCNC spindle product includes the following core components:
1. Spindle Motor
Air-cooled or water-cooled, depending on your order.
Rated 1.5kW or 2.2kW.
• ER11 (65mm) or ER20 (80mm) for manual tool change
• ISO20 taper for ATC systems
📷 Photo Suggestion:
Line up the three motor types side-by-side (65mm ER11, 80mm ER20, ISO20 ATC) with labels.
2. Delixi EM61 VFD
All PwnCNC spindle products use the same EM61 VFD platform.
The VFD is:
Pre-programmed for your spindle model
Tested with a motor before shipment
Configured with safe acceleration and protection settings
📷 Photo Suggestion:
Front and side photo of EM61 VFD with key terminals highlighted.
3. Spindle Power Cable
Shielded cable with aviation connector (motor side).
- Spindle Kits come with flat spade connector on the VFD side
- Spindle and ATC Systems come with an aircraft connector on the VFD side
4. Controller Cable
Used to connect your CNC controller to the VFD for automatic RPM control.
The exact termination depends on what you ordered.
- Spindle Kits come with generic ferrule connectors on the VFD side
- Spindle and ATC Systems come with a GX12 aircraft connector on the VFD side
5. Basic Collets
Manual spindle systems include standard ER11 or ER20 collets.
ATC systems include ER20 collets that can be installed into the four included ISO20 tool holders.
Now let’s break down what differs by product type.
🔹 If You Purchased a Spindle Kit
A Spindle Kit includes:
Bare Delixi EM61 VFD (not enclosed)
Spindle motor
Shielded motor cable
Controller signal cable (terminated appropriately)
Basic collets
This option is ideal if:
You are building your own enclosure
You are comfortable wiring mains power
You prefer to integrate electronics yourself
⚠️ You are responsible for mounting and protecting the VFD inside an enclosure.
📷 Photo Suggestion:
Show the non-enclosed EM61 VFD next to the enclosed version for comparison.
🔹 If You Purchased a Spindle System
A Spindle System includes everything from the Kit, plus:
VFD installed inside our plug-and-play enclosure
Pre-wired AC input
Integrated aircraft connectors
External control ports
IoT port
This version eliminates enclosure wiring and reduces installation complexity.
You simply:
Mount the enclosure
Plug in AC power
Connect the motor cable
Connect your controller cable
📷 Photo Suggestion:
Show closed enclosure and open enclosure view to highlight internal wiring cleanliness.
🔹 If You Purchased an ATC System
An ATC System includes:
ISO20 ATC spindle motor
EM61 VFD (in enclosure)
Pneumatics Enclosure (PE)
ATC control cable
(4) ISO20 tool holders with matching ER collets
Tool holder racks (flush style)
Additional requirements (not included):
Air compressor
Air dryer / moisture separator
Extra tool holders if expanding tool count
📷 Photo Suggestion:
Lay out:
ATC spindle
VFD enclosure
Pneumatics enclosure
Tool holders
Tool racks
Clear overhead layout shot works best here.
What Is Not Included
To avoid confusion:
• CNC controller
• Air compressor (ATC only)
• Air dryer (ATC only)
• Dust boot
• Mounting bracket (unless ordered)
• Electrical circuit wiring
Before You Continue
Once you’ve verified your components:
➡ Proceed to Mechanical Installation → Mounting the Spindle
Do not apply power yet.
Mechanical mounting and cable routing should be completed first.
If anything is unclear or appears incorrect, contact support before continuing. It is much easier to fix an issue before installation than after wiring is complete.
