07. Installing & Mounting Proximity Homing Switches
This article covers how to properly install and mount the proximity homing switches included with PwnCNC Conversion Kits.
Correct homing is foundational. When done properly, it gives you:
  • Reliable startup behavior
  • Repeatable zero positions
  • Accurate squareness between axes
When done poorly, it leads to:
  • “Won’t home” errors
  • Random homing failures
  • Machines that slowly drift out of square
The good news is that proximity switches are very forgiving once you understand a few basics.
What Type of Switches We Use
All PwnCNC Conversion Kits ship with normally open (NO), inductive proximity switches.
That means:
  • The switch is inactive by default
  • It becomes active only when metal
  • No physical contact is required
This is intentional. Normally open sensors are:
  • More tolerant of noise
  • Easier to diagnose
  • Safer in the event of wiring issues
You do not need to configure normally closed logic for these switches.
How Proximity Switches Detect Position
Inductive proximity switches detect metal, not motion.
They do not care about:
  • Speed
  • Direction
  • How hard something hits them
They do care about:
  • Distance to the metal target
  • Size and type of metal
  • Alignment and repeatability
What Can Be Used as a Target
The following all work well as homing targets:
  • Steel plates
  • Steel angle
  • Steel machine frames
  • Steel screw heads or bolts
  • Aluminum
📸 Photo placeholder: examples of acceptable targets
If your machine does not already have metal targets, adding a simple steel bolt or plate is often the easiest solution.  Alternatively you can also use conductive copper tape:  https://amzn.to/3ZYusik
Mounting Distance and Alignment
This is the most important part.
Typical detection range is:
  • 1–2mm from the target surface
Best practices:
  • Mount the switch so it approaches the target squarely
  • Avoid angled or glancing approaches
  • Ensure the switch sees the same surface every time
📸 Photo placeholder: correct vs incorrect alignment
You do not need micron-level precision here. Consistency matters more than perfection.
Normally Open vs Normally Closed (In Practice)
With normally open switches:
  • Open circuit = not homed
  • Closed circuit = homed
This makes troubleshooting straightforward:
  • If the machine says a switch is triggered when nothing is near it, something is wrong
  • If the machine never sees the switch, you’re likely too far from the target
This simplicity is why we standardize on NO sensors.
Axis Squareness: How Square Is “Good Enough”?
Short answer: Very good, not perfect.
Homing switches define repeatability, not absolute squareness.
Key points:
  • The machine frame defines mechanical square
  • Homing switches just return you to the same reference point every time
  • Minor misalignment is corrected by machine calibration, not switch placement
As long as:
  • Both sides of a gantry trigger consistently
  • Switches are mounted securely
  • Targets do not move
You are well within acceptable limits.
📸 Photo placeholder: dual-Y homing example
Common Mistakes to Avoid
Avoid these and you’ll prevent most homing issues:
  • Mounting switches too far from the target
  • Using aluminum or stainless targets with low magnetic response
  • Letting the switch or target flex during motion
  • Mounting the switch where chips or dust can pack between it and the target
  • Over-tightening the switch body and damaging the internal sensor
Quick Test Before Final Mounting
Before committing to final mounts:
  1. Temporarily zip-tie or clamp the switch in place
  2. Manually jog the axis toward the target
  3. Watch the Masso input status
  4. Confirm repeatable triggering
Once confirmed, finalize the mount.
When to Pause and Ask for Help
Stop and reach out if:
  • A switch triggers randomly
  • An axis refuses to home consistently
  • The input shows active with no metal present
  • You’re unsure whether your target material will work
Photos go a long way here.
Next Steps
Once switches are mounted:
  • Proceed to Homing Verification & Direction Checks
  • Then First Motion Test (No Spindle)
Correct homing is the foundation of a stable CNC. Taking the time here pays off immediately.
