06. Conversion Kit Advanced Wiring (Step-by-Step)
This article walks through the step-by-step wiring process for the PwnCNC Masso Conversion Kit – Advanced.
If you have not already done so, stop here and read the following first:
πŸ‘‰ Conversion Kit Wiring Overview (Read Before Wiring Anything)
That article explains grounding, shield drains, and important rules that apply to all Conversion Kits. This page assumes you’ve read and understood that information.
What This Article Covers
This guide shows where everything goes in the Advanced controller once you begin wiring.
It does not attempt to explain why each wire exists, only where it lands. All wiring is shown using the aircraft connectors and prewired components included in your kit.
Sections in This Guide
  • Overall controller layout
  • Wiring stepper motors
  • Wiring homing (proximity) switches
  • Powering the system
  • Prewired inlet panel overview
  • Optional accessories (spindle, tool setter, probe, MPG, rotary, ATC)
πŸ“Έ Photos and diagrams will be added to each section. For now, follow the order exactly as written.
Before You Begin
Do not apply power yet.
Before wiring:
  • Verify all stepper motors are mounted and mechanically aligned
  • Identify the Z-axis motor with the electric brake
  • Confirm your machine has a defined grounding point
  • Leave all accessories unplugged for now
Overall Controller View
The Advanced controller ships with:
  • Masso G3 Touch controller installed
  • Power distribution boards
  • Step-down converter
  • Internal fusing already completed
πŸ“Έ Image placeholder: overall internal controller layout
Your goal is to match this final state before power-up.
Wiring the Stepper Motors (Controller Side)
Each stepper motor cable includes:
  • Power wires
  • Phase wires
  • Encoder wires
  • Shield drain
Steps:
  1. Route stepper cables through the cable management channels inside the enclosure
  2. Land phase and encoder wires into the labeled phoenix connectors for each axis
  3. Connect alarm outputs to their assigned Masso inputs
  4. Terminate shield drains at your designated grounding point
πŸ“Έ Image placeholder: stepper wiring inside controller
Wiring the Stepper Motors (Motor Side)
At the motor:
  • Match wire colors to the motor terminal labels
  • Confirm DIP switch configuration matches your motor type
  • Ensure connectors are fully seated
πŸ“Έ Image placeholder: motor wiring
πŸ‘‰ For DIP switch configuration, see:
Closed Loop Stepper Configuration
Wiring the Homing (Proximity) Switches
Each proximity switch requires:
  • 24V power
  • Signal wire to Masso input
  • Ground reference
Steps:
  1. Connect power wires to the 24V distribution board
  2. Route signal wires to the assigned Masso inputs
  3. Verify switch polarity and mounting orientation
πŸ“Έ Image placeholder: homing switch wiring
Powering the Conversion Kit
The Advanced kit includes a 36V power supply pre-installed in the power box.
Steps:
  1. Set the input voltage selector (110V or 220V)
  2. Connect AC input power using a C13 power cable
  3. Verify DC output before proceeding
πŸ“Έ Image placeholder: power box
Powering the Controller
The controller is powered via:
  • 36V input
  • Internal step-down conversion to 24V
This wiring is pre-installed and should not be modified.
πŸ“Έ Image placeholder: internal power distribution
Prewired Inlet Panel Overview
The Advanced kit includes a fully prewired inlet panel supporting:
  • Spindle
  • Tool Setter
  • XYZ Probe
  • Rotary Axis
  • ATC system
Each inlet is already routed to the correct Masso terminals.
πŸ“Έ Image placeholder: inlet panel wiring
If you are not installing an accessory yet, leave that inlet unused.
Optional Accessories
Only install accessories you are ready to configure.
Supported accessories include:
  • Spindle systems
  • Tool setter
  • XYZ probe
  • MPG pendant
  • Rotary axis
  • ATC system
Each has a dedicated KB article with wiring and configuration details.
Before First Power-Up
Before applying power:
  • Double-check all ferrules are fully seated
  • Confirm shield drains are grounded
  • Verify no loose strands or exposed conductors
  • Ensure motors can move freely by hand
Once complete, proceed to:
πŸ‘‰ Initial Power-Up & Axis Verification (coming soon)
Need Help?
If something does not match what you see:
We’re happy to review before power-up.
