Home > Spindles & ATCs > Misc > Converting from LongMill with LongBoard to the AltMill
Converting from LongMill with its LongBoard to the AltMill
Are you converting from a Sienci Labs LongMill with a LongBoard controller to their AltMill?  We can help.
Moving your PwnCNC Spindle from brand/controller to another is very easy and often only requires a different control cable + a few programming settings.
You can find our control cables here:  https://pwncnc.com/products/control-cable?variant=44989134536843
Specify if you have our Spindle Kit (with unenclosed VFD) or our Spindle System (with enclosed VFD)
Programming
Programming is simple as it only requires a few codes:
P0.0.03=2 - On/Off Automatic Source
P0.0.04=3 - Frequency Automatic Source
P4.1.00=04 - Modbus Baud Rate
P4.1.01=3 - Modbus Data Format
After you've made the switch... you can refer to this article for details on setting up gSender and wiring into the SuperLongBoard-ext.
If you have questions reach out to us at:  [email protected]
