Home > Spindles & ATCs > Misc > Converting from 1f to AltMill
Are you converting from a 1f CNC machine to the AltMill from Sienci Labs?  We can help.
Moving your PwnCNC Spindle from brand/controller to another is very easy and often only requires a different control cable + a few programming settings.
You can find our control cables here:  https://pwncnc.com/products/control-cable
Spindle Kit
If you have a Spindle Kit you need the Generic Ferrules to wire directly into phoenix terminals.
With our Spindle System you need the GX12 2-pin for Modbus Control
https://pwncnc.com/products/control-cable?variant=42676941553803
Programming
Please reach out to us for a clear answer on what programming settings need to change.
[email protected]
