Welcome to the Dominator Pro — your professional-grade CNC platform, built for power, precision, and upgradeability. This article covers essential operating instructions to get you started, stay safe, and ensure consistent performance with every job.
✅ Before You Power On
Make sure the following is completed before using the machine:
✅ Machine is fully assembled per the Dominator Pro Build Series on YouTube
✅ VFD and spindle are installed, wired, and properly configured
✅ All motion cables (X/Y/Z and spindle) are securely connected
✅ Air supply is connected (if using ATC or air assist features)
✅ Emergency stop (E-stop) and limit switches tested
✅ Masso controller (or other) is powered, configured, and communicating with the machine
🟢 Starting the Machine
1. Power On Sequence
Turn on your main power source
Ensure air compressor is running (if ATC or air-based accessories are used)
Wait for the Masso controller to initialize and display its main screen
Release the E-stop (if pressed)
2. Reference Axes
Use the Masso UI to “Home All Axes”
This sets the machine’s origin using limit switches.
🧰 Jogging & Setup
Use the jog keys or on-screen controls to move each axis.
Load your material and secure it using clamps or vacuum.
Set the tool length (via touch plate or Tool Setter if equipped)
Set your work origin (X, Y, Z zero)
🌀 Spindle Operation
Spindle is controlled via Masso (M3/M5) or VFD front panel
RPM is set via PWM or analog voltage — typically 0.10–10.00V
Make sure your spindle has been broken in before cutting:
🔧 See: Spindle Break-In Guide →
🔄 Running Jobs
Load G-code onto Masso (via USB or network)
Confirm tool and work offset are correct
Hit Cycle Start on the Masso interface
Monitor the job — use the E-stop if needed
🛠️ After the Job
Turn off spindle (M5)
Retract Z-axis safely
Vacuum or wipe down bed
Turn off air supply and power if done for the day
🧼 Maintenance Checklist
| Task | Frequency |
| Clean linear rails & ballscrews | Daily |
| Check spindle collet & nut | Before every job |
| Verify air pressure & filters | Weekly |
| Tighten motor & drive hardware | Monthly |
| Back up Masso configuration | Quarterly |
📎 Additional Resources
⚠️ Safety Notice:
Always disconnect power and air supply before servicing. Follow all safety precautions. PwnCNC products are intended for skilled users building or operating hobbyist to light industrial CNC systems.
💬 Still Need Help?
If you run into issues during your first setup, our support team is here to help.
📩 Contact PwnCNC Support →
