Home > Spindles & ATCs > Misc > Safety & Compliance Overview
At PwnCNC, safety and reliability are foundational to everything we ship. Whether you are installing a spindle kit, spindle system, ATC system, or a full Dominator CNC, the motor and VFD components included in our systems are sourced from manufacturers that perform formal safety and compliance testing.
We are also actively working with a third-party laboratory to pursue additional testing of our systems as complete integrated assemblies.
This article explains what certifications exist today, what they mean, and why they matter in real-world CNC use.
CE Certification (Conformité Européenne)
Both our GPenny spindle motors and Delixi EM61 VFDs are manufactured to meet CE requirements.
CE compliance indicates that the product conforms to applicable European directives related to:
  • Electrical insulation and leakage protection
  • Electromagnetic compatibility (EMC)
  • Mechanical integrity under rated load
  • Low Voltage Directive (LVD) safety requirements
CE compliance ensures the components meet established electrical and thermal safety standards for operation within the EU.
📄 CE documentation is available upon request.
UL-Referenced Testing (North American Safety Standards)
Our spindle motors are manufactured to meet UL-referenced safety testing standards commonly applied to electrical motor systems in North America.
Testing frameworks typically include:
  • Overload and short-circuit evaluation
  • Insulation resistance and thermal rise
  • Grounding path verification
  • Housing and cable safety validation
While these motors may not carry an official “UL Listed” mark as a finished consumer product, they are built and tested to meet recognized UL safety criteria for equivalent safe operation when installed properly.
📄 Test documentation is available upon request.
Why This Matters in a CNC Environment
CNC spindle systems operate in a demanding electrical environment:
  • High-speed motors up to 24,000 RPM
  • 110–220V AC mains power
  • Long cable runs along machine frames
  • PWM or analog control signals from controllers
Using components that meet recognized electrical safety standards helps ensure:
  • Stable startup and shutdown behavior
  • Proper insulation under load
  • Reduced electrical noise
  • Predictable VFD protection behavior
Safety-certified components do not eliminate the need for proper installation, but they provide a strong foundation for reliable operation.
Installation Still Matters
Even certified components must be installed correctly to maintain safe operation.
We recommend:
  • Using shielded spindle power cable
  • Properly grounding the shield drain at the VFD
  • Bonding the machine frame to earth ground
  • Following our spindle break-in procedure
  • Following air supply safety guidelines for ATC systems
Most reliability issues stem from grounding, wiring, or power quality, not from motor or VFD certification itself.
Questions or Documentation Requests
If you are integrating a PwnCNC spindle into a custom machine, working with an electrician, or require compliance documentation for your shop, contact our support team and we will provide the appropriate documentation.
