Home > Spindles & ATCs > Misc > Can I Run a 2.2kW Spindle on 110V?
Short answer:
Yes, technically you can, but it is not ideal and we do not recommend it for most users.
What Is Possible
A 2.2kW spindle can be powered from a 110V input VFD if all of the following are true:
  • The VFD is specifically rated for 110V input
  • The VFD outputs 3-phase power to the spindle
  • The spindle’s current draw stays within the limits of the VFD and your electrical circuit
The Delixi EM61 VFD we stock is available in a 110V version, and we have tested it with 2.2kW spindles in real-world CNC use. Under light to moderate cutting loads, it does function correctly.
That said, there are important limitations to understand before choosing this setup.
Important Limitations of 110V on a 2.2kW Spindle
Running a spindle of this size on 110V comes with tradeoffs:
Lower available power
You will not get the spindle’s full rated torque, especially under load.
Higher current draw
A 2.2kW spindle on 110V pushes the limits of typical 15A or 20A household circuits.
Startup sensitivity
Acceleration or spin-up may trip breakers or cause intermittent startup issues.
Reduced performance at high RPM
Maintaining full RPM while cutting can be unstable under heavier loads.
Thermal stress
The VFD may run hotter, and additional cooling or airflow may be required.
For engraving, light woodworking, plastics, or short jobs, this may be acceptable. For aluminum, hardwood, deeper cuts, or long runtimes, these limits become very noticeable.
When 220V Is the Right Choice
You should strongly consider 220V input if you plan to:
  • Run the spindle near full RPM for extended jobs
  • Cut aluminum or dense hardwoods
  • Use higher feedrates or deeper passes
  • Run aggressive toolpaths or high acceleration profiles
  • Expect long-term reliability without thermal concerns
With a 220V EM61 VFD you get:
  • Full torque across the spindle’s RPM range
  • Lower current draw and less stress on wiring
  • More stable spindle speed under load
  • Improved reliability and cooler operation
You do not need three-phase wall power. A standard single-phase 220V circuit, like those used for dryers or welders, is sufficient.
PwnCNC Real-World Recommendation
Based on our testing and customer experience:
  • 110V is acceptable if you have no other option and your work is light-duty
  • 220V is strongly recommended for consistent torque, stable RPMs, and long-term reliability
  • 🚫 Do not rely on a 15A 110V circuit for demanding or production-level work with a 2.2kW spindle
If you are planning a new CNC build or upgrade, designing around 220V from the start will save frustration later.
Related Resources
  • Choosing Between 110V and 220V VFDs
  • Delixi EM61 VFD Overview
  • Understanding VFD Power Limits and Protection
Still Not Sure?
If you are trying to work within electrical limitations or want help choosing the right spindle and VFD combination, reach out to our support team. We would much rather help you plan correctly than troubleshoot an underpowered setup later.
