We currently support and supply the Delixi EM61 series VFD, available in both 110V and 220V versions, ideal for powering 1.5kW and 2.2kW air- or water-cooled spindles in hobby and semi-pro CNC machines.
📘 What Is a VFD, and Why Do You Need One?
A Variable Frequency Drive is a device that converts standard wall power (AC) into a variable-frequency output that controls the speed and torque of a 3-phase spindle motor. Without a VFD, you can’t safely run a CNC spindle or adjust its speed dynamically through software.
VFDs offer:
Adjustable spindle speed from 0 to 24,000 RPM
Smooth motor acceleration and braking
Overload protection and thermal safeguards
Remote control integration via CNC software or hardware switches
⚙️ The PwnCNC-Recommended VFD: Delixi EM61
We’ve tested several options and standardized around the Delixi EM61 for its:
Compact footprint
Easy setup with GRBL, Masso, and Other controllers
Dependable cooling and heat management
Support for both 110V and 220V input (international ready)
Read full product description →
📂 VFD Documentation Index
To help you navigate, here are the core guides and topics available in this section:
🧰 Setup & Installation
🛠️ Configuration & Parameters
Quick Start Guide: Delixi EM61 Basic Parameters
Adjusting Acceleration, Braking, and Frequency Ranges
How to Reverse Spindle Rotation
🌍 Voltage & Compatibility
Can I Run a 2.2kW Spindle on 110V?
International Setup Notes for EU, UK, AU, etc.
🧪 Troubleshooting & Maintenance
My VFD Isn’t Powering the Spindle — Now What?
🔥 Current Promotions
We’re currently offering a flash sale on Delixi EM61 VFDs to reduce inventory. Both 110V and 220V models are available for a limited time.
🛒 Shop the Sale Now →
📄 Download the Updated EM61 VFD Datasheet (PDF)
💬 Need Help?
If you’re stuck, confused, or just want to verify your setup before powering on, we’re here to help.
📩 Contact PwnCNC Support
🧠 Or browse more articles in the VFD Knowledge Base →
