Home > CNC Accessories > Inlet Cables > Tower Light Cable Inlet
The requirements for the Tower Light are an external power supply and a relay.
Wiring is simple after you have these though.
There are 5 wires, Black, White, Red, Yellow, Green.
Black is ground
White is the Buzzar
Red is the Red Light
Yellow is the Yellow Light
Green is the Green Light
If you don't have our Conversion Kit, you'll need additional wires. According to Masso's Documentation you should have ferrule connectors on there so a loose wire does not cause any problems.
Jumper a cable from V+ to 3 or 4 of the relay's common terminals.
Here we see a T-Spliced daisy chain being used to supply the power to the relay's common ports (right).
Plug the wires in from the Tower Inlet into the Normally Open ports (middle)
Next, plug cables from the relay output to the Masso output, and assign accordingly then plug the black wire into any ground port.
Note: There is not currently an audible alarm output from Masso. If you tie the buzzer into the Red Light as I did with the ferrule going into Masso, the beeper will sound every time the red light turns on.
Now over to the programming:
https://support.pwncnc.com/kb/article/512-tower-light/
