Home > Spindles & ATCs > ATC (Subsection) > Installation > Manual Tool Change (MTC) Button
🔧 Manual Tool Change (MTC) Button — What You Need to Know
The Manual Tool Change (MTC) Button is a completely optional feature—you do not need it to use the Automatic Tool Changer (ATC) system on your machine.
That said, it can be a handy tool for manually swapping out tool holders without needing to go through the Masso controller or G-code programming.
✅ What the MTC Button Does
  • Manually opens the spindle clamps so you can insert or remove a tool.
  • Lets you bypass Masso’s programmed tool change sequence.
  • Acts like pressing the spacebar on Masso, which inverts the clamp output.
🔐 Safety Requirements
The MTC Button will only work when the spindle is in a safe state, meaning:
  • The spindle’s RPM is at zero (fully stopped).
  • The safety wire between the VFD and the Pneumatics Enclosure is properly connected.
💡 Indicator Light:
  • Lit = Active (ready to use)
  • Off = Inactive (spindle is not in a safe state)
🔄 How to Use It
  1. Press the button to open the clamps.
    • Be ready: the tool may drop or be ejected if not supported.
  2. Insert a new tool, then release the button.
  3. Wait a few seconds for the clamps to automatically lock the tool in place.
🧠 Tips for Large Diameter Tools (e.g., Spoilboard Cutters)
Because of the way Masso and ATC logic handle large tools, here's a common workaround:
  • Add a “dummy” tool position in your rack for the large tool (e.g., spoilboard bit).
  • Program your toolpath to change to that dummy tool number.
  • After the ATC completes the tool change, manually install the large bit using the MTC Button.
This method works around limitations for tools that don't physically fit in the rack.
🔍 Note: Masso shows a button in the interface that suggests future support for this, but it’s currently inactive. We’re actively exploring additional tool rack options to address this.
🔁 Alternative Option
For large tools that don’t fit in the rack, you can also switch to a Manual Tool Change (F1 Tool Change Window) for just that toolpath, instead of using ATC.
