May 03, 2024
The controller inlet cable is designed to bring our vfd's control cable into a controller's enclosure. It has a GX12 6-pin panel connector on one side, 18" 20awg wires and ferrules on the other plugging into the actual controller.
although 6-pins, only 5 will need to be soldered.
pin 1 = black = Ground
pin 2 = red = PWM
pin 3 = yellow = Forward/CW
pin 4 = white = Digital Common
pin 5 = green = Reverse/CCW
pin 6 = unused
