CNC4Newbies Demon Controllers
Manual Mode Operation
Wiring your Spindle to Demon Controller for Automatic Mode Operation
Spindle System Wiring
Spindle Kit Wiring
This mode is where your CNC controller controls the VFD via a simple PWM variable voltage signal.  For Demon this is 0-5v representing 0-24000rpms.
We have pre-programmed your VFD to run in automatic mode when the Manual Override switch is flipped to automatic (down or 0 position).  The vfd will monitor the PWM (red wire) and GND (black wire) for how fast the controller is instructing the VFD to spin the spindle motor.  You must still hit the "RUN" button on the VFD's keypad to change the vfd from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
P0.0.04 = 3
P2.0.02 = 9
P2.0.15 = 05.00
Your Demon is not capable of triggering an internal relay so you'll need to hit the "RUN" button on the VFD's keypad to change the vfd from standby/stopped mode (blinking keypad display) to spin/forward mode (solid keypad display).
Setting up your Demon Controller for Automatic Mode Operation
We have played with Demon controllers before and here are a few notes we've gathered as to how to configure UCcnc for controlling a spindle:
For configuring your UCcnc software you’ll want to adjust your Configuration -> Spindle settings to match these:
Quick_Start_-_cnc4newbie_Demon.pdf
