Carbide3d's Shapeoko
If you’d like to run your spindle in manual mode, flip the “Manual Override” switch up or “1” to enable VFD Keypad controls. Then use the Run/Stop and Potentiometer dial on the front of your VFD to run your motor.
If you’d like to automatically control your spindle via g-code and the Shapeoko’s controller, perform the following:
Your VFD has come preprogrammed to accept a PWM signal between 0 and 5 volts. This matches the signal the Carbide Controller sends out.
From within Carbide Motion V5 navigate to the Settings->Options and change the Spindle to “VFD Spindle”. Hit OK at the bottom and confirm sending configuration to your machine.
If you are operating on V6 or higher, you will need to reconfigure Carbide Motion from initial machine setup to see the spindle enable button.
That’s it… just remember to properly configure your RPM’s when working within Carbide Create or other CAD software and with a carbide controller hit run after every power cycle or stop/reset of the VFD.
Notes: If you have a Shapeoko 5, you'll need to install the warthog pigtail as seen here
If using carbide motion as your controller software, when in setup, ensure that bit runner is disabled. Even if selecting VFD spindle if it was on before, it is still on but ghosted as experienced in build 618.
Notes: Do not enable bit runner, and if it is enabled but ghosted, you will need to reconfigure carbide motion for a router to deselect the Bit Runner so it can be disabled.
If you have any questions, reach out to us at [email protected]
If you're here you're interested in wiring up our EM61 VFD into your Shapeoko's Controller provided by Carbide3d, then you're in the right place.
Goal:  Wire up our VFD into the Shapeoko Controller to allow their controller to control the speed of the spindle motor.
Carbide/Shapeoko Wiring Diagram
Wiring up the Shapeoko controllers is relatively easy.  The Red and Black wire coming from our PWM cable can be wired directly into the Shapeoko.
We also have the proper control cable with the correct Molex connector attached available here: https://pwncnc.com/products/control-cable?variant=40795625324683
Note:  If your machine does not have the Molex connector on the end, all hope is not lost, please reach out to us at [email protected] for further assistance.
1 out of 2 found this helpful
Quick_Start_Guide_-_Shapeoko_5.pdf Quick_Start_Guide_-_Shapeoko.pdf
