Home > Spindles & ATCs > Misc > Using the IoT Port on PwnCNC Spindle Systems
Automatic Control of Dust Collection and Accessories
PwnCNC spindle systems include an IoT control port on the VFD enclosure that allows the spindle system to automatically control external accessories such as a shop vac or coolant pump.
This feature is designed to simplify CNC operation by reducing the number of manual switches required when starting and stopping a job.
How It Works
We use an IoT power control solution from Digital Loggers, which integrates cleanly with our spindle systems.
Each PwnCNC spindle system includes:
  • An IoT control plug
  • A low-voltage 2-conductor signal connection exposed from the VFD enclosure
By connecting this signal wire between the VFD enclosure and the Digital Loggers IoT Power Strip, the spindle system can automatically switch an outlet on or off based on spindle activity.
Automatic Shop Vac Control
The most common use case is dust collection.
  • The IoT Power Strip includes an “Usually Off” outlet
  • Your shop vac is plugged into this outlet
  • When the spindle ramps above approximately 5500 RPM, the VFD outputs the control signal
  • The IoT Power Strip activates the outlet, turning the shop vac on
  • When the spindle slows down or stops, the outlet turns off automatically
This happens without any CNC software configuration. It is handled entirely by the spindle system and VFD.
Electrical Limits and Compatibility
There are a few important limitations to be aware of:
  • The IoT Power Strip can control multiple AC loads up to 12 amps total
  • This is sufficient for most shop vacs
  • Larger dust collectors that draw high startup current may exceed this limit and are not recommended
Voltage Limitations
  • The Digital Loggers unit used here operates on 12–120VAC
  • This makes it suitable primarily for use in the United States
  • At this time, a 220V version is not available
Other Supported Uses
In addition to dust collection, customers often use this feature to control:
  • Spindle coolant pumps
  • Auxiliary fans or small accessories
If you use the IoT port to control a coolant pump, we strongly recommend adding a third-party flow indicator. This provides a visual confirmation that coolant is flowing when CNC operations begin.
What This Feature Is Not
  • This is not a high-power motor starter
  • It is not designed for large dust collectors
  • It does not replace proper electrical safety devices
  • It does not provide feedback to the CNC controller
It is intended as a convenience automation feature, not an industrial control system.
Technical Reference
We’ve attached the Digital Loggers technical datasheet to this article for customers who want deeper electrical and signaling details.
Final Notes
The IoT port is one of those “quality of life” features that many customers end up loving once it’s installed. It reduces steps, improves workflow, and helps keep CNC operation consistent from job to job.
If you’re unsure whether your accessory is compatible with this setup, feel free to contact support before connecting it.
If you have additional questions, please reach out to us at [email protected]
iot2spec.pdf
