Manual and Programming
Our Version 1 spindle kit manual is packed full of valuable knowledge related to your enclosed VFD.  It is so packed full of information that it can sometimes be an overload to the uninitiated.
Be very careful performing certain actions described within the manual... some will wipe your VFD's programming and could void your warrantee.
You'll also find attached our v1 programming guide.  This paper includes our internal wiring diagram and VFD program settings required to make this all work.
Our VFD is wired the same regardless of your control method (Modbus vs PWM) however the functionality exposed through the control cable is limited.
We program the VFD with your motor and general settings on page 1 while page 2 outlines program settings specific to each control method and wiring.
Programming_VFD_v1.pdf
