Jan 20, 2024
635
Version 2 received the greatest advances in VFD enclosures... checkout this upgrades video.
In this version we introduced two optional upgrades to your existing v2 spindle kit... Low-Power and High-Power. Combined you'll get a fully plug-n-play spindle kit unlike anything else on the market.
On the right side you'll find our EMI filtering Power Inlet as well as a special spindle-cable inlet.
On the left you'll find a 4-pin control cable inlet, IoT Power Strip signal port, and a "Manual Override" switch.
Like before, the "Running Pause" button is in the bottom center of the front panel.
