Features
A big step forward in EMI control and VFD protection was our full enclosure.  This version includes pre-wired spindle and control cables. These are wired through an opening in each side of the enclosure passing through to the inner VFD where it is wired up.
This version can programmed for either automatic OR manual control and can not switch between them without some minor reprogramming.
It also features a "Running Pause" button will stop the spindle motor from turning regardless of the input controls.  Most folks will typically leave this P logo'd button pressed in unless they're changing bits.
