How to Export Your MASSO Controller Settings to a USB Drive
Your MASSO controller can save a backup of its machine configuration to a USB flash drive. This backup can be useful for troubleshooting, restoring your machine, or helping other owners configure a similar CNC conversion.
Saving a backup does not change or erase your current settings. It only copies them to the USB drive.
What You Will Need
You will need a USB flash drive that meets the following requirements:
  • Formatted as FAT32
  • Uses an MBR partition
  • Preferably 32 GB or smaller
  • A recognized name-brand USB drive is recommended
If you already use a USB drive successfully with your MASSO controller, you can use that drive.
Exporting Your MASSO Settings
  1. Insert the USB flash drive into your MASSO controller.
  2. From the main MASSO screen, open the F1 Setup screen.
  3. Open the Save and Load Calibration Settings window.
  4. Select Save to file.
  5. Wait for MASSO to finish saving the files before removing the USB drive.
Important: Be sure to select Save to file. Do not select Load from file, because that option is used to replace the controller’s current configuration with settings already stored on the USB drive.
MASSO will save the following files:
  • MASSO_Settings.htg — contains the machine’s calibration and configuration settings
  • MASSO_Tools.htg — contains the controller’s tool table
Please send us both files when possible. The MASSO_Settings.htg file is the most important, but the tool-table file can also help us understand the complete configuration.
Finding the Files on Your Computer
  1. After the save process is complete, remove the USB drive from the MASSO controller.
  2. Insert the USB drive into your computer.
  3. Open the USB drive using File Explorer on Windows or Finder on macOS.
  4. Open the MASSO folder.
  5. Open the Machine Settings folder.
  6. Locate these two files:
MASSO_Settings.htg
MASSO_Tools.htg
Attaching the Files to Your Email
Reply to the email you received from PwnCNC and include the following information:
  • CNC manufacturer or brand
  • Exact CNC model
  • Machine cutting size or overall size
  • MASSO model, such as MASSO G3 Touch, G3 Touch Advanced, or MASSO Core
  • PwnCNC Conversion Kit used
  • Any notable accessories, such as an ATC spindle, tool setter, touch probe, rotary axis, or custom homing sensors
Attach both .htg files to your reply and send the email.
If your email provider will not allow .htg attachments, place both files into a ZIP file and attach the ZIP file instead.
A suggested ZIP filename is:
Brand-Model-Size-MASSO-Backup.zip
For example:
Onefinity-Woodworker-X50-32x48-MASSO-Backup.zip
Please do not open or edit the .htg files before sending them.
Privacy Information
MASSO does not include your Wi-Fi network security key in the exported settings backup. The Wi-Fi password field is intentionally left blank when settings are saved.
Helping the CNC Community
PwnCNC is collecting conversion information and controller backups from customers who have successfully installed our MASSO Conversion Kits on different CNC machines.
Our goal is to build a reference library containing:
  • Compatible CNC brands and models
  • Machine sizes
  • Wiring and sensor information
  • Known configuration requirements
  • Example MASSO settings from successful conversions
These resources may help future conversion owners begin with a proven reference configuration for a similar machine.
Any shared configuration should still be reviewed carefully before being loaded onto another CNC. Motor calibration, travel limits, homing direction, inputs, outputs, spindle control, and other settings can vary even between machines of the same model.
For additional information, refer to the official MASSO Save & Load Settings documentation.
