01. What to Know Before Converting Your CNC Machine
Before purchasing or installing a PwnCNC Conversion Kit, confirm what the conversion will replace, which original components can be reused, and whether your machine requires mechanical or electrical adaptation.
Important: A controller conversion replaces or modernizes the machine's control system. It does not correct worn bearings, binding linear motion, damaged ball screws, poor alignment, frame problems, or other existing mechanical faults.
A PwnCNC Conversion Kit can provide a modern MASSO-based control system, cleaner wiring, improved serviceability, and a path toward additional features. The difficulty of the installation, however, depends heavily on the original machine.
Some machines use standard motors, mounts, couplers, switches, and spindle-control methods. Others rely on proprietary electronics, undocumented connectors, integrated motor drivers, or custom mechanical assemblies. Identifying those differences before ordering can prevent delays and unexpected parts purchases.
1. Determine which type of conversion you have
Most projects fall into one of three categories:
Conversion type What it means What to expect
Documented Your machine appears in PwnCNC's compatibility information or machine-specific research. Follow the published parts list, wiring guidance, and configuration information for that machine.
Adaptable The machine uses mostly standard components, but some connectors, couplers, brackets, sensors, or cables must be adapted. Measure and identify the affected components before ordering additional parts.
Custom or research The machine is undocumented, proprietary, heavily modified, or uses components with unknown specifications. Expect independent research, electrical testing, fabrication, and configuration work. Compatibility cannot be assumed.
If your machine is not specifically documented, treat the project as an adaptable or custom conversion until every important mechanical and electrical interface has been verified.
2. Understand what the kit replaces
A conversion normally centers on the controller and motion-control electronics. Depending on the selected kit and options, it may also replace or add motors, motor drivers, motor cables, homing sensors, controller wiring, connectors, and related hardware.
The machine's frame, linear motion components, drive system, spindle mount, dust collection, and other mechanical assemblies generally remain in service unless the project specifically includes replacements.
Always use the current product listing as the definitive record of what is included. Do not assume that an existing cable, sensor, coupler, mount, spindle, VFD, probe, or accessory is included or compatible unless it is explicitly identified.
3. Choose the appropriate conversion platform
PwnCNC offers Core and Advanced conversion paths. Product specifications and available options may change, so review the current product pages before ordering.
Platform General fit Consider it when
Conversion Kit Core A cost-conscious MASSO conversion focused on essential machine control and motion. You need a clean controller upgrade for a conventional CNC router or spindle configuration and do not require the broader expansion path of the Advanced platform.
Conversion Kit Advanced A MASSO G3 Touch Advanced conversion with greater expansion capability and a more complete path for advanced accessories. You plan to use an ATC, require additional inputs or outputs, want greater expansion flexibility, or may eventually migrate the electronics to a Dominator Pro.
4. Do not assume the original motors can be reused
Stock motors are often one of the least documented parts of an OEM machine. A motor may look like a standard NEMA 23 motor while still having an incompatible shaft, current requirement, encoder, connector, integrated driver, or proprietary feedback system.
Reusing unknown motors can make wiring, tuning, and troubleshooting substantially more difficult. Possible symptoms include incorrect direction, weak or erratic motion, overheating, driver alarms, missed position, or an inability to use the original feedback system.
For the most predictable and supportable result, use the motors, drivers, and motor cables specified for the selected PwnCNC kit whenever practical. PwnCNC closed-loop motors provide position feedback to their matched drivers, but they cannot correct mechanical binding, poor alignment, loose couplers, or an incorrectly configured machine.
Record the following for every original motor
  • Manufacturer and model number
  • NEMA frame size and mounting-hole pattern
  • Motor current, voltage, step angle, and wiring information
  • Open-loop or closed-loop design
  • Separate or integrated motor driver
  • Shaft diameter, shaft length, and shaft style
  • Connector type and documented pinout
  • Available clearance around the motor and cable
5. Measure the motor mounts and drive connections
A new motor may match the original NEMA frame size but still fail to fit the machine. Bolt spacing, pilot diameter, shaft length, motor-body clearance, and cable orientation all matter.
The motor must also connect correctly to the machine's ball screw, lead screw, belt pulley, pinion, or other drive component. Couplers are not universal.
Confirm these dimensions before ordering
  • Motor mounting-hole spacing and pilot diameter
  • Original and replacement motor shaft diameters
  • Ball-screw, lead-screw, pulley, or drive-shaft diameter
  • Required coupler bore on each end
  • Coupler length and available installation space
  • Shaft engagement depth and set-screw or clamp locations
  • Whether an adapter plate, spacer, pulley, or custom bracket is required
Measure both sides of every coupler. Common dimensions such as 6.35 mm (1/4 inch), 8 mm, and 10 mm are not interchangeable.
6. Inspect the original wiring and connectors
Original machine wiring may be reusable only when its conductor count, wire size, shielding, condition, connector pinout, and electrical purpose are known. Proprietary connectors or matching plug shapes do not prove electrical compatibility.
Plan to replace, adapt, extend, or re-terminate wiring when the original cables have:
  • Unknown or undocumented pinouts
  • Proprietary connectors
  • Damaged, brittle, pinched, or contaminated insulation
  • Insufficient conductor count or wire size
  • Inadequate shielding for the intended signal
  • Shared conductors or grounds that do not match the new design
  • Insufficient length for the new controller location or drag-chain route
This review applies to motor cables, homing sensors, limit switches, probes, tool setters, E-stops, spindle-control cables, VFD connections, and accessory wiring.
7. Identify every homing and limit sensor
Mechanical switches, optical sensors, inductive sensors, and Hall-effect sensors can use different voltages and output circuits. A sensor may be normally open or normally closed, and an electronic sensor may use NPN, PNP, sourcing, or sinking logic.
Before reusing a sensor, identify:
  • Exact manufacturer and model number
  • Supply-voltage range
  • Output type and logic
  • Normally open or normally closed behavior
  • Wire colors and their verified functions
  • Connector pinout
  • Whether the MASSO input requires a pull-up, resistor jumper, or interface circuit
  • Physical sensing distance and target material
Never identify sensor wiring by color alone. Verify the model's documentation or test the device safely before connecting it to the controller.
8. Treat spindle and VFD control as a separate compatibility check
Converting the motion controller does not automatically make the existing router, spindle, or VFD compatible. The new controller must use a control method supported by the spindle system.
Identify whether the machine uses:
  • A manually operated trim router
  • A router controlled through a relay
  • A VFD using run/stop contacts
  • A VFD using a 0-10 V speed signal
  • A VFD using PWM through an interface
  • A VFD using RS-485 or Modbus communication
  • A proprietary spindle or controller interface
Record the router or spindle model, VFD model, input voltage, motor ratings, existing control method, and all relevant terminal or connector labels. Do not connect a VFD control cable based only on connector appearance.
9. Confirm machine layout, axis count, and cable lengths
The machine's physical size and construction affect motor count, driver count, cable length, homing configuration, and controller placement.
Confirm:
  • Machine brand, model, size, and approximate year
  • Actual X-, Y-, and Z-axis travel
  • Drive type on each axis: ball screw, lead screw, rack, belt, or other
  • Number of motors and which axis each motor drives
  • Whether the gantry uses one motor or independently driven motors on both sides
  • Whether independent gantry homing and squaring are required
  • Existing and proposed controller locations
  • Required cable lengths and drag-chain routes
  • Available mounting space for the controller, drivers, power supplies, and enclosures
A 2-by-4-foot and a 4-by-4-foot version of the same machine may use similar electronics while requiring different cable lengths, routes, or sensor locations.
10. Plan power, grounding, and electrical safety before installation
Controller power, motor power, spindle power, protective earth, DC common, and cable shielding serve different purposes. They must be connected according to the applicable wiring documentation.
  • Confirm the available AC service and the requirements of every device.
  • Use correctly sized branch circuits, conductors, overcurrent protection, disconnects, and enclosures.
  • Bond exposed conductive machine parts and required enclosures to protective earth.
  • Follow the published guidance for shield drains and signal-cable routing.
  • Keep low-voltage signal wiring separated from VFD output and other high-noise wiring where practical.
  • Do not use protective earth as a substitute for a DC signal return.
  • Complete a point-to-point inspection before applying power.
Electrical hazard: VFDs and mains-powered equipment can retain dangerous voltage after power is removed. Work inside mains-voltage equipment should be performed only by someone qualified to do so and in accordance with applicable electrical codes.
11. Document the machine before disassembly
Before removing the original controller or cutting any cable, create a record of the working machine. This makes identification and troubleshooting much easier later.
  • Photograph the complete machine and controller installation.
  • Photograph every connector before unplugging it.
  • Label both ends of every cable.
  • Record motor, sensor, power-supply, spindle, and VFD model numbers.
  • Save the original controller settings and configuration when possible.
  • Record axis directions, homing directions, travel limits, and existing steps-per-unit values.
  • Measure couplers, shafts, mounting patterns, cable lengths, and controller clearances.
  • Keep removed parts organized until the converted machine has been fully tested.
12. Complete this checklist before ordering
  • Confirm that the machine is mechanically sound and moves freely.
  • Check PwnCNC's published compatibility information and machine-specific research.
  • Choose the Core or Advanced conversion path.
  • Confirm the number and size of replacement motors required.
  • Measure motor mounts, shafts, couplers, pulleys, and clearances.
  • Identify all homing switches, limit switches, probes, and tool setters.
  • Identify the router, spindle, VFD, and intended control method.
  • Confirm AC power, grounding, enclosure, and cable-routing requirements.
  • Verify cable lengths for the machine size and controller location.
  • List every adapter, bracket, coupler, connector, or cable not included with the kit.
  • Review the current product listing for included components, options, lead time, and stated compatibility.
Support and compatibility expectations
PwnCNC's published instructions and machine-specific research cover the configurations we have been able to document or test. Information gathered from other machines may also be shared as community research, but it should not be treated as a guarantee that every production revision uses identical components.
For undocumented machines, the owner or installer is responsible for verifying mechanical fit, electrical compatibility, pinouts, safe wiring, and final configuration. PwnCNC Support can clarify the documented operation of PwnCNC products, but custom engineering, reverse-engineering of proprietary systems, and complete design reviews for unknown machines are outside normal product support.
Support is provided by email at [email protected]. Include your order number, machine brand and model, a concise description of the question, relevant measurements, and clear photos of model labels and connections. Requests are normally reviewed during the published support window.
Recommended next steps
  1. Read 00 - Start Here: PwnCNC Conversion Kit Overview & Install Flow.
  2. Review the appropriate What's in the Box article for the Core or Advanced kit.
  3. Check 05 - Machine-Specific Research for information about your machine or brand.
  4. Document and measure the original machine before ordering or disassembly.
  5. Continue to 02 - Installation & Wiring only after compatibility and required adaptations are understood.
A successful conversion begins with verified information. Identify the machine, understand what the kit replaces, measure every mechanical interface, document each electrical connection, and resolve unknowns before power is applied.
