Home > Spindles & ATCs > D. Controller Integration > PWM vs 0–10V: How Your Controller Actually Talks to the VFD
When your CNC controller tells the spindle to run at a specific RPM, it must communicate that request to the VFD.
That communication happens in one of two ways:
  • True 0–10V analog voltage
  • PWM (Pulse Width Modulation)
Understanding the difference removes most spindle speed confusion.
Two Ways to Send Speed Commands
1️⃣ True 0–10V Analog (The Ideal Method)
This is the cleanest and most stable method.
The controller outputs a real voltage between:
  • 0V = 0 RPM
  • 10V = Maximum RPM
The VFD simply reads that voltage and scales it proportionally.
Example:
Voltage Spindle Speed (24,000 max)
5V 12,000 RPM
7.5V 18,000 RPM
10V 24,000 RPM
This method is:
  • Smooth
  • Stable
  • Predictable
  • Industrial standard
Controllers like Masso and Centroid typically provide true analog output.
2️⃣ PWM (Voltage Simulation)
Many hobby CNC controllers do not output true analog voltage.
Instead, they output a digital PWM signal.
PWM works by rapidly turning a 5V signal on and off. The average voltage over time simulates analog.
The VFD then interprets that average as speed.
But here’s the key:
PWM is a simulation of voltage.
Not actual voltage.
Why Cheap Controllers Don’t Output Perfect Voltage
A controller labeled as:
  • “0–5V PWM”
  • “0–10V PWM”
Rarely outputs exactly 5.00V or 10.00V.
In reality, you might see:
  • 4.82V
  • 4.96V
  • 9.7V
  • Non-linear scaling across the range
This is normal behavior for hobby-level electronics.
It is not a defect.
But it does affect spindle speed accuracy.
What This Looks Like in Practice
You may notice:
  • Spindle never quite reaches full RPM
  • Spindle starts too fast
  • RPM does not match commanded value
  • Speed feels compressed or inconsistent
This is almost always scaling mismatch, not wiring failure.
When You Need a Digital-to-Analog Converter
Some controllers output PWM that is too noisy or unstable for direct VFD use.
In those cases, a PWM-to-0–10V converter is required.
The converter:
  • Accepts digital PWM
  • Converts it into a clean analog 0–10V signal
  • Feeds that to the VFD’s analog input
This improves:
  • Stability
  • Maximum RPM accuracy
  • Low-speed control resolution
Where the Converter Physically Goes
The converter should be installed:
  • Near the CNC controller
  • Between the controller PWM output and the VFD analog input
Signal flow:
Controller PWM → Converter → VFD Analog Input
The converter:
  • Receives power (often from VFD 10V reference and ground)
  • Outputs a clean voltage to the VFD
Keep signal wires short and away from high-voltage spindle cables.
Scaling Adjustments Are Normal
Even with true 0–10V analog, some tuning may be required.
The EM61 VFD allows:
  • Minimum frequency adjustments
  • Maximum frequency scaling
  • Fine mapping between voltage and RPM
This means you can adapt the VFD to your controller’s real-world output.
You are not expected to have a mathematically perfect controller.
The VFD is designed to compensate.
Matching Controller Settings to the VFD
Proper spindle behavior depends on:
  • Correct RUN source
  • Correct frequency source
  • Correct scaling
  • Matching acceleration timing
If speed feels wrong, the problem is usually:
  • Signal scaling
  • Voltage range mismatch
  • Acceleration timing mismatch
Not hardware failure.
True Analog vs PWM Summary
Feature True 0–10V PWM
Stability Excellent Varies by controller
Accuracy High Depends on quality
Requires converter No Sometimes
Industrial standard Yes No
When to Upgrade to True Analog
You may benefit from true analog control if:
  • You need precise RPM repeatability
  • You are cutting aluminum or steel
  • You run consistent production jobs
  • You want minimal tuning
For wood and hobby work, PWM is usually acceptable when tuned correctly.
Key Takeaway
Your controller does not send RPM.
It sends voltage.
The VFD converts voltage into spindle speed.
If the voltage is imperfect, the RPM will be imperfect.
That’s normal.
The system is designed to accommodate it.
Understanding that prevents unnecessary troubleshooting and eliminates most “my spindle speed is wrong” tickets.
