Home > Spindles & ATCs > A. Start Here > 1. Spindle Kit vs Spindle System: What's the Difference?
Spindle Kit vs Spindle System: What’s the Difference?
If you’re here, you’re likely deciding between a Spindle Kit and a Spindle System — or trying to understand what makes them different.
The short answer:
Both use the same spindle motors.
Both use the same Delixi EM61 VFD.
Both produce the same cutting performance.
The difference is in integration, enclosure, and electrical refinement.
What Is a Spindle Kit?
“Spindle Kit VFD – functional, but requires enclosure and installation planning.”
A Spindle Kit includes:
  • Spindle motor (air or water cooled)
  • Delixi EM61 VFD
  • Motor cable
  • Power cable
  • Control cable
  • Basic documentation
The VFD is not enclosed in a finished housing.
You are responsible for:
  • Mounting or enclosing the VFD safely
  • Routing wiring cleanly
  • Managing strain relief
  • Implementing grounding properly
It is a clean, capable solution for experienced users who are comfortable working with electrical components.
What Is a Spindle System?
“Spindle System – same VFD, professionally integrated.”
A Spindle System includes everything in the Kit, plus:
  • Professionally built enclosure
  • Integrated power inlet
  • Aviation connectors
  • Proper strain relief
  • Grounding provisions
  • IoT port (if applicable)
  • Pre-configured layout for cleaner installs
The VFD inside is the exact same EM61 — it is simply installed in a purpose-built enclosure.
This removes electrical guesswork.
Performance Is Identical
This is important:
A Spindle Kit and a Spindle System will perform the same once installed correctly.
There is no hidden firmware difference.
There is no internal upgrade.
You are paying for:
  • Integration
  • Safety refinement
  • Reduced wiring decisions
  • Cleaner long-term reliability
Why Many Customers Choose the System
Over the years, we noticed a pattern.
Customers who bought Kits sometimes:
  • Mounted VFDs loosely
  • Skipped proper grounding
  • Overlooked strain relief
  • Used undersized enclosures
  • Experienced EMI-related issues
Not because the Kit was flawed — but because electrical integration matters.
The System was created to remove those variables.
Who Should Choose a Spindle Kit?
Choose the Kit if you:
  • Are comfortable wiring and enclosure design
  • Already have an electrical cabinet
  • Prefer full control over layout
  • Want the most cost-efficient entry point
Who Should Choose a Spindle System?
Choose the System if you:
  • Want plug-and-play refinement
  • Prefer not to design an enclosure
  • Value clean wiring
  • Want reduced installation variables
  • Plan to upgrade machines in the future and move the system easily
Can I Upgrade Later?
Yes.
If you start with a Spindle Kit, you can send the VFD back and upgrade to our enclosure later.
Many customers do this once they see the benefit of a refined install.
What About ATC Systems?
ATC Systems are different.
They include:
  • Industrial 4-pole spindle
  • Pneumatic control enclosure
  • Safety interlocks
  • Tool-change integration
ATCs build on top of the Spindle System foundation and include additional components.
ATC details are covered in the dedicated ATC section.
The Bottom Line
Spindle Kit = Same performance. More DIY.
Spindle System = Same performance. Less risk. Cleaner install.
We designed both intentionally.
The right choice depends on how much electrical integration you want to handle yourself.
