Home > Dominator CNC > Conversion Kit > First Test Jobs & Safe Speeds
Why Slower Is Smarter on Day One
Once your machine powers on, homes correctly, and jogs as expected, it’s tempting to jump straight into a “real” job. This is where many first-time issues happen.
This article explains how to validate your setup safely, what to run first, and why conservative settings save time, tools, and frustration.
Jogging vs Running G-code
Before running any program:
  • Jog each axis manually
  • Verify motion direction
  • Confirm smooth movement without alarms
  • Listen for unusual sounds
Jogging is about confirming behavior, not accuracy. If jogging feels wrong, running a program will make it worse.
Your First Job Should Be Boring
Your first job is not about productivity. It’s about proof.
Good first jobs:
  • Simple squares
  • Circles
  • Shallow facing passes
  • Air cuts above the material
Bad first jobs:
  • Deep pockets
  • Aggressive adaptive toolpaths
  • Hard materials
  • Long unattended runs
If it feels too easy, that’s the point.
Conservative Feeds and Speeds
On day one, aim for:
  • Lower feed rates than normal
  • Shallow depth of cut
  • Moderate RPMs
  • Single-pass operations
Even if your machine and spindle are capable of much more, this is not the time to find the limit.
A successful slow cut proves:
  • Motion is stable
  • Acceleration timing is correct
  • Spindle control is working
  • No unexpected alarms occur under load
Most early failures come from:
  • Overconfidence
  • Aggressive settings copied from another machine
  • Assuming “it worked before” applies here
Your machine may look similar to a previous setup, but the electronics, tuning, and dynamics are new. Slowing down gives you time to observe and react.
Watch the Machine, Not the Screen
During first cuts:
  • Stay with the machine
  • Watch the tool
  • Listen for changes in sound
  • Be ready to stop immediately
Do not walk away. Do not assume it will finish.
What Is Normal During First Cuts
Normal:
  • Slightly rough finish
  • Conservative material removal
  • Pauses between moves
  • Minor tuning adjustments needed later
Not normal:
  • Motor alarms under light load
  • Spindle speed instability
  • Harsh vibration
  • Missed steps or stalls
If something feels wrong, stop and reassess.
After the First Successful Cut
Once you’ve completed:
  • A clean homing cycle
  • Smooth jogging
  • One or two simple cuts
Then you can begin:
  • Increasing feeds gradually
  • Increasing depth of cut
  • Testing different materials
One change at a time.
Final Thought
Breaking a bit on day one is rarely a hardware problem.
It’s usually a setup, expectation, or patience problem.
Slow, simple, and boring builds confidence and saves money.
If you’re unsure what to try next, reach out before pushing harder.
We’d rather help you tune than help you recover.
