Home > Dominator CNC > Conversion Kit > 9. First Power-On Checklist
What’s Normal, What’s Not, and When to Stop
The first power-on after installing a Conversion Kit can feel stressful. New electronics, new motors, new controller. This checklist is here to help you know what to expect, what’s normal, and what should make you stop immediately.
Read this before powering on for the first time.
Before You Apply Power
Do a quick visual check:
  • All stepper motors are plugged in
  • All connectors are fully seated
  • No loose ferrules or exposed conductors
  • Homing switches are mounted but not actively triggered
  • Nothing is mechanically binding
  • Grounding is connected or planned
If anything feels rushed, stop and fix it now. First power-on is not the time to “see what happens.”
Powering On: What You Should See
Controller Behavior
  • The Masso Touch screen powers on normally
  • No error messages immediately on boot
  • The interface loads to the main screen
This confirms the controller and power supply are healthy.
Stepper Motors
  • Motors may energize with a slight “click” or resistance
  • Z-axis motor brake may audibly release
  • Motors should not move on their own
This is normal and expected.
Indicator Lights
  • Closed-loop stepper motors may show:
    • Green or steady status LEDs
    • No flashing alarm lights
If all motors show alarms immediately, stop and recheck wiring and grounding.
Sounds You May Hear (Normal)
  • A faint hum from energized steppers
  • A brief relay click inside the controller
  • Cooling fans turning on
These are normal.
Sounds That Are NOT Normal
Stop immediately if you hear:
  • Grinding or binding sounds
  • Repeated clicking from motors
  • High-pitched squealing
  • Rapid on/off cycling
These indicate mechanical or wiring issues that must be corrected before continuing.
First Homing Attempt
Before jogging any axis far, run a homing cycle.
What should happen:
  • Axes move slowly toward homing switches
  • Each axis triggers its switch and backs off slightly
  • Machine settles into a known home position
If an axis moves the wrong direction, stop immediately. Do not “see what happens.”
Errors That Are Acceptable (Initially)
Some errors are normal during first power-on and setup:
  • Homing fails due to switch alignment
  • Axis alarms due to misconfigured direction
  • Limit switch triggers if mounted too close
These are configuration or mounting issues, not hardware failures.
Errors That Are NOT Acceptable
Stop and do not continue if you see:
  • Multiple motor alarms at once
  • Alarms immediately on boot
  • Motors energizing but not releasing
  • Smoke, smell, or heat buildup
  • Errors that persist after power cycling
Continuing past these can cause permanent damage.
Before Your First Cut
Confirm all of the following:
  • Homing completes successfully
  • Jogging works in all directions
  • Axis directions match expectations
  • No alarms during idle movement
  • Spindle control works as expected
Only after this should you move on to cutting material.
When to Pause and Ask for Help
Pause and contact support if:
  • You’re unsure whether behavior is normal
  • An alarm keeps returning
  • Something feels “off” but you can’t explain why
Catching issues early prevents expensive fixes later.
Photos or a short video help us help you faster.
Final Reminder
A calm, deliberate first power-on sets the tone for everything that follows.
Nothing about this process should feel rushed.
If it does, stop and reassess.
You’re building a machine meant to last.
