Home > Dominator CNC > Conversion Kit > 7. Ground Your Conversion Kit
Read This Even If It “Works”
Proper grounding is not optional on a CNC machine.
It is a requirement for reliability, safety, and long-term health of your electronics.
Many grounding-related failures do not show up immediately. They appear weeks later, often after a dry day, a shop vac run, or a single static discharge.
This article explains what needs to be grounded, why it matters, and how to do it correctly.
The Big Picture
Your CNC system has three different concepts that often get confused:
  • Signal ground
  • Chassis ground
  • Earth ground
They are related, but they are not the same thing.
A system can appear to work perfectly while still being improperly grounded. That is why grounding issues are some of the hardest to diagnose after the fact.
Earth Ground Is the Reference Point
Earth ground is the final destination for all noise, static, and fault energy.
Examples of acceptable earth ground points:
  • A grounded electrical outlet
  • A grounded electrical panel
  • A properly bonded grounding bar
  • A dedicated ground rod bonded to your electrical system
Everything else ultimately needs a clean path back to earth.
Chassis Ground vs Earth Ground
Your controller enclosure, motor frames, and VFD enclosure are chassis ground elements.
Chassis ground must be bonded to earth ground.
If a metal enclosure is floating, meaning not bonded to earth, it can accumulate static or noise and discharge unpredictably.
That discharge often finds the weakest path, which is usually a signal wire or motor driver.
Shielded Cables and Shield Drains
Your Conversion Kit stepper cables are physically shielded.
That shielding is there to:
  • Absorb electrical noise
  • Provide a safe path for interference
  • Protect signal integrity
But the shield only works if it is grounded.
Where Shield Drains Should Go
All stepper cable shield drains should be tied to a single grounding point, typically:
  • A grounding block
  • A grounding stud
  • A bonded metal enclosure tied to earth
This is often called a star ground.
Do not daisy-chain grounds from motor to motor.
Do not leave shields floating.
Floating shields are worse than no shields at all.
Shop Vacs and Static Are Real
Shop vacs generate massive static electricity, especially with:
  • Plastic hose
  • Dry air
  • Long hose runs
  • MDF or wood dust
Static does not care that your CNC worked yesterday.
A single discharge can:
  • Trip Masso motor alarms
  • Latch closed-loop stepper faults
  • Damage driver inputs
  • Cause intermittent axis failures
This is why many grounding-related failures appear suddenly and seem random.
Why Problems Often Appear Weeks Later
Improper grounding causes cumulative stress, not instant failure.
Common patterns:
  • Machine works fine at first
  • Occasional unexplained alarms
  • One axis faults, then clears
  • Eventually multiple axes alarm together
  • Reboots do not fix it
At that point, damage may already be done.
Grounding early prevents this entirely.
What to Ground on a Conversion Kit
At minimum, ensure the following are bonded:
  • Controller enclosure to earth
  • Grounding block to earth
  • Stepper motor cable shields to grounding block
  • VFD enclosure to earth
  • Machine frame to earth
All of these should reference the same earth point.
What Not to Do
Never:
  • Rely on USB ground alone
  • Assume the machine frame is grounded through the bench
  • Leave shield drains disconnected
  • Ground shields at both ends
  • Tie shields into signal ground terminals
  • Ignore static shocks, even small ones
If you feel a static shock, your system felt it too.
Quick Grounding Sanity Check
You should be able to verify continuity with a multimeter between:
  • Machine frame and earth
  • Grounding block and earth
  • Shield drain and earth
  • Controller chassis and earth
If any of these are floating, stop and correct it.
When to Stop and Contact Support
Reach out if:
  • You are unsure where to terminate shields
  • Your machine alarms began after a static event
  • Multiple axes fault simultaneously
  • Alarms persist after power cycling
Photos of grounding points help tremendously.
Final Note
Grounding is not about making the machine run today.
It is about ensuring it still runs months from now.
Most “mystery” Masso motor alarm tickets trace back to grounding and static.
Doing this right once saves you from chasing ghosts later.
