04. First Homing & Axis Direction Check
This article walks you through the very first power-on, homing, and axis direction check after installing a PwnCNC Conversion Kit.
Do not rush this step.
Everything that follows, jogging, probing, cutting, depends on this behaving correctly.
What to Expect the First Time You Power On
On first power-up, a few things are normal and expected:
  • The Masso Touch boots normally
  • The machine does not move on its own
  • Motors may feel stiff or locked when powered
  • No axes should be actively driving yet
If anything moves immediately on power-up, stop and power down.
That is not expected behavior.
Before You Press “Home”
Before homing for the first time:
  • Make sure nothing can crash
  • Remove tools, clamps, and workpieces
  • Move the gantry and Z axis roughly to the middle of travel
  • Keep one hand near the E-Stop
This gives every axis room to move in either direction safely.
First Homing Cycle: What Should Happen
When you press Home, you should see:
  1. One axis move slowly toward its homing switch
  2. The axis stop when the switch is detected
  3. The axis back off slightly
  4. The next axis repeat the process
This continues until all axes are homed.
This motion should be:
  • Slow
  • Controlled
  • Predictable
📸 Photo placeholder: homing sequence screen
Stop Immediately If You See Any of the Following
Hit E-Stop or power down if:
  • An axis moves away from its switch at speed
  • An axis keeps moving after contacting the switch
  • An axis slams into a hard stop
  • Motors growl, chatter, or stall loudly
  • The gantry twists during homing
Do not “let it finish and see what happens.”
Stopping early prevents damage.
Axis Direction Sanity Check (Critical Step)
After homing completes successfully, do not jog far yet.
Perform this simple direction check:
X Axis
  • Jog -X
  • Machine should move to the Left
Y Axis
  • Jog -Y
  • Machine should move towards you (toward the front)
Z Axis
  • Jog -Z
  • Z should move down, towards the table
Use small jog increments only.
📸 Photo placeholder: jog arrows and axis directions
If an Axis Moves the Wrong Direction
This is common on first setup and not a failure.
Do not swap motor wires.
Do not rewire anything.
Simply:
  • Reverse the axis direction in Masso settings
  • Re-test with small jogs
This is exactly why this check exists.
Do Not Jog to Extremes Yet
At this stage:
  • Do not jog to full travel
  • Do not probe
  • Do not run g-code
  • Do not mount the spindle yet
The goal here is basic correctness, not full operation.
What Success Looks Like
You are ready to move on when:
  • Homing completes cleanly every time
  • Each axis moves in the expected direction
  • Small jogs behave predictably
  • No alarms or stalls occur
Once this is confirmed, you can proceed confidently.
When to Pause and Ask for Help
Stop and contact support if:
  • Homing fails repeatedly
  • An axis refuses to move
  • Directions cannot be corrected in software
  • You’re unsure whether behavior is normal
Photos or short videos help us diagnose quickly.
Next Step
Proceed to:
“Jogging, Soft Limits, and Travel Verification”
This is where you safely confirm full travel before cutting anything.
