This article walks you through the very first power-on, homing, and axis direction check after installing a PwnCNC Conversion Kit.
Do not rush this step.
Everything that follows, jogging, probing, cutting, depends on this behaving correctly.
What to Expect the First Time You Power On
On first power-up, a few things are normal and expected:
The Masso Touch boots normally
The machine does not move on its own
Motors may feel stiff or locked when powered
No axes should be actively driving yet
If anything moves immediately on power-up, stop and power down.
That is not expected behavior.
Before You Press “Home”
Before homing for the first time:
Make sure nothing can crash
Remove tools, clamps, and workpieces
Move the gantry and Z axis roughly to the middle of travel
Keep one hand near the E-Stop
This gives every axis room to move in either direction safely.
First Homing Cycle: What Should Happen
When you press Home, you should see:
One axis move slowly toward its homing switch
The axis stop when the switch is detected
The axis back off slightly
The next axis repeat the process
This continues until all axes are homed.
This motion should be:
Slow
Controlled
Predictable
📸 Photo placeholder: homing sequence screen
Stop Immediately If You See Any of the Following
Hit E-Stop or power down if:
An axis moves away from its switch at speed
An axis keeps moving after contacting the switch
An axis slams into a hard stop
Motors growl, chatter, or stall loudly
The gantry twists during homing
Do not “let it finish and see what happens.”
Stopping early prevents damage.
Axis Direction Sanity Check (Critical Step)
After homing completes successfully, do not jog far yet.
Perform this simple direction check:
X Axis
Jog -X
Machine should move to the Left
Y Axis
Jog -Y
Machine should move towards you (toward the front)
Z Axis
Jog -Z
Z should move down, towards the table
Use small jog increments only.
📸 Photo placeholder: jog arrows and axis directions
If an Axis Moves the Wrong Direction
This is common on first setup and not a failure.
Do not swap motor wires.
Do not rewire anything.
Simply:
Reverse the axis direction in Masso settings
Re-test with small jogs
This is exactly why this check exists.
Do Not Jog to Extremes Yet
At this stage:
Do not jog to full travel
Do not probe
Do not run g-code
Do not mount the spindle yet
The goal here is basic correctness, not full operation.
What Success Looks Like
You are ready to move on when:
Homing completes cleanly every time
Each axis moves in the expected direction
Small jogs behave predictably
No alarms or stalls occur
Once this is confirmed, you can proceed confidently.
When to Pause and Ask for Help
Stop and contact support if:
Homing fails repeatedly
An axis refuses to move
Directions cannot be corrected in software
You’re unsure whether behavior is normal
Photos or short videos help us diagnose quickly.
Next Step
Proceed to:
“Jogging, Soft Limits, and Travel Verification”
This is where you safely confirm full travel before cutting anything.
