This article covers one of the most important and most overlooked parts of installing a conversion kit: mechanical alignment between the motor and the drive system.
Poor alignment causes:
Binding and lost motion
Excessive vibration
Closed-loop stepper faults
Overheating motors
Premature bearing and coupler failure
If your motors “alarm,” “buzz,” or feel stiff to turn by hand, start here.
NEMA 23 Assumptions
All PwnCNC conversion kits are designed around NEMA 23 stepper motors.
This assumes:
Your machine has NEMA 23 motor mounting patterns
Motor shafts are concentric with the driven screw or pulley
Motor faces sit flat against the mounting surface
21mm long and 8mm diameter stepper motor shafts are usable on your machine
If a mount is twisted, spaced incorrectly, or flexing under load, alignment will suffer no matter how good the electronics are.
Coupler Basics (And What They Are Not)
Most machines use a flexible coupler, typically aluminum with a spiral or jaw design.
A coupler:
Compensates for minor misalignment
Does not fix poor motor mounting
Is not meant to bend or preload continuously
If a coupler is visibly flexing at rest, something is wrong.
Proper Shaft Engagement
Each side of the coupler should:
Engage the shaft fully, but not bottom out
Leave a small gap in the center of the coupler
Clamp on the shaft, not on the radius or chamfer
Do not let:
Shafts bottom out inside the coupler
Set screws clamp on rounded edges
One side grab more shaft than the other
These are common causes of vibration and motor faults.
Alignment by Feel, Not Force
Before tightening anything:
Mount the motor loosely
Slide the coupler on both shafts
Rotate the screw or pulley by hand
It should turn smoothly with:
No tight spots
No rhythmic resistance
No visible wobble
If it binds:
Do not tighten the motor “harder”
Loosen and realign instead
Force hides problems until something fails.
How Tight Is “Tight Enough”
Coupler set screws:
Firm, not crushed
Use thread locker, not brute force
Tighten against flat portions of the shaft if present
Motor mounting bolts:
Snug and evenly torqued
Motor face fully seated against mount
No gaps, rocking, or distortion
Over-tightening can warp mounts and misalign shafts.
Common Mistakes That Damage Motors
Avoid these:
Tightening couplers before alignment
Using rigid couplers with imperfect mounts
Letting the coupler preload the motor shaft
Mounting motors to flexible or thin plates
Ignoring hand-rotation resistance
Closed-loop motors will report faults when these issues exist. That is a feature, not a defect.
Quick Sanity Check Before Power-On
Before applying power:
You should be able to move each axis smoothly by hand
No grinding, popping, or pulsing resistance
Motors should not “snap” into position when turned slowly
If it does not feel right by hand, it will not behave under power.
When to Pause and Ask
Stop and contact support if:
An axis binds no matter how you align it
Motors fault immediately on enable
A coupler heats up during motion
Vibration increases with speed
Fixing alignment early prevents cascading failures later.
Next Article
Continue to:
Grounding, Shielding, and EMI for Conversion Kits
or
First Power-On Checklist
