Home > Spindles & ATCs > Troubleshooting > When a VFD Error Means Hardware Service Is Required
Most VFD errors are protective and recoverable. They exist to stop damage before it happens.
However, a small number of errors indicate that the VFD itself may have experienced an internal fault. When this happens, further troubleshooting or repeated resets can make the situation worse.
This article explains how to recognize those cases early and what to do next.
Two Categories of VFD Errors
All VFD errors fall into one of two categories:
1. User-Fixable / Configuration-Related
These are caused by:
  • Power quality issues
  • Aggressive acceleration settings
  • Load conditions
  • Wiring mistakes external to the VFD
These errors usually clear once the underlying cause is corrected.
2. Internal Hardware-Related
These indicate a failure or abnormal condition inside the VFD.
When these occur, continued operation or repeated resets can:
  • Damage internal components
  • Cause cascading failures
  • Turn a recoverable issue into a permanent one
Errors That Require Hardware-Level Attention
If you encounter any of the following errors, stop troubleshooting and contact support.
ERR31 – Current Detection Fault
What it means:
The VFD’s internal current-sensing circuitry is reporting abnormal behavior.
Why this matters:
Current detection is a core safety system. When it fails, the VFD can no longer reliably monitor motor load.
Do not:
  • Repeatedly reset and retry
  • Continue running under load
ERR33 – Abnormal Current Detection
What it means:
The VFD is receiving invalid or inconsistent current feedback from its sensing hardware.
Common causes:
  • Internal driver board issues
  • Hall sensor malfunction
Important:
This is not caused by spindle load or cutting parameters.
ERR37 – Driving Power Supply Fault
What it means:
The internal power supply that drives the VFD’s control electronics is unstable or failed.
Why this is serious:
The VFD cannot safely control output power when its internal supply is compromised.
ERR26 – Parameter Read-Write Abnormality
What it means:
The VFD’s non-volatile memory (EEPROM) cannot reliably store or retrieve parameters.
Symptoms may include:
  • Parameters not saving
  • Random resets
  • Inconsistent behavior after power cycling
This is an internal memory fault.
Why Continued Troubleshooting Can Make Things Worse
When hardware-level faults occur:
  • The VFD may no longer correctly protect itself
  • Repeated resets can stress damaged components
  • Running under load can cause permanent failure
At this point, more testing is not safer testing.
Stopping early preserves the best chance of recovery.
What You Should Do Instead
If you encounter ERR31, ERR33, ERR37, or ERR26:
  1. Power the system down
  2. Do not continue cutting or jogging
  3. Do not repeatedly reset the fault
  4. Contact support with the error code and context
Include:
  • Error code shown
  • When it occurred
  • Whether it repeats immediately
  • Any recent wiring or power changes
What This Article Is Not Saying
This does not mean:
  • You caused the failure
  • Your spindle is bad
  • Your setup was careless
Electronic components can fail, and protective systems exist to limit damage when they do.
Recognizing when an error crosses from “configuration issue” into “service required” is part of using industrial electronics responsibly.
Key Takeaway
Some errors are warnings.
Some errors are boundaries.
Knowing the difference protects your equipment — and your time.
If an error indicates internal hardware failure, stopping early is the correct decision.
