Home > Spindles & ATCs > C. VFD & Power > Power Quality for CNC Spindles: What Actually Matters
Many “random” spindle faults are not random at all. They are the VFD doing its job and protecting your spindle when incoming power is unstable or outside safe limits.
This article explains what power quality actually means for CNC spindles, why it matters, and how to avoid the most common electrical issues before they become frustrating interruptions.
Why Power Quality Matters More Than You Think
A VFD is constantly monitoring voltage, current, and internal bus stability. If it sees a condition that could damage the spindle or itself, it will fault and shut down intentionally.
Errors like ERR04, ERR05, ERR06, ERR08, and ERR40 are not failures. They are protective responses.
In almost every case, these errors are caused by power delivery issues upstream of the VFD.
Dedicated Circuits vs Shared Circuits
A dedicated circuit means the VFD is the only significant load on that breaker.
This matters because shared circuits introduce voltage drop when other devices turn on.
Common problem devices include:
  • Dust collectors
  • Shop vacs
  • Air compressors
  • Heaters
  • Large routers or saws
Even if those devices are on 110V and your VFD is on 220V, they may still share the same panel leg, neutral, or feeder wiring. When they start, they can cause momentary voltage sag that the VFD detects immediately.
Best practice:
  • One breaker, one circuit, one VFD
  • No other high-draw equipment on the same circuit
Voltage Sag Under Load
Voltage sag is a short drop in voltage when load increases suddenly.
This commonly happens:
  • When the spindle plunges into material
  • During aggressive acceleration
  • When braking quickly
  • When another machine starts at the same time
On 110V systems, there is much less headroom. A small sag can push the voltage below the VFD’s minimum threshold, triggering ERR08 under-voltage.
This is why under-voltage errors often appear only when cutting begins, not at idle.
Extension Cords, Wire Gauge, and Long Runs
Extension cords are one of the most overlooked causes of VFD faults.
Common issues:
  • Undersized wire gauge
  • Long cable runs
  • Coiled cords causing heat buildup
Even a heavy-duty looking extension cord can drop significant voltage under load.
General guidance:
  • Avoid extension cords whenever possible
  • If unavoidable, use the shortest run possible
  • Use oversized wire gauge, not the minimum rating
  • Never coil excess cable while in use
For permanent installs, properly sized fixed wiring is always preferred.
Why Dust Collectors and Compressors Matter So Much
Dust collectors and compressors draw very high current at startup, often several times their running current.
That startup surge can cause:
  • Momentary voltage collapse
  • DC bus instability inside the VFD
  • ERR04, ERR05, ERR06, or ERR40 faults
Even if the spindle itself is lightly loaded, another machine starting nearby can trip a fault instantly.
If you see faults that coincide with another machine starting, this is almost always the cause.
Why 220V Is More Forgiving Than 110V
This is one of the biggest takeaways.
At 220V:
  • Current draw is roughly half for the same power
  • Voltage sag has less impact
  • Wiring losses are reduced
  • The VFD operates more efficiently
  • Errors are far less common under load
At 110V:
  • Current is high
  • Breakers trip more easily
  • Voltage drops faster under load
  • Power quality matters much more
This is why 220V systems feel “more stable” even when doing the same work.
If you are running a 2.2kW spindle, or pushing harder materials, 220V is strongly recommended.
Common Symptoms of Power Quality Problems
If you experience any of the following, power quality should be the first thing you check:
  • Spindle faults only when cutting
  • Random shutdowns during plunges
  • Errors after long jobs
  • Errors that disappear after resetting
  • Problems that seem worse at certain times of day
These are classic signs of voltage instability, not bad hardware.
What the VFD Is Actually Doing
When a VFD faults, it is saying:
“I detected a condition that could damage the spindle or myself, so I stopped.”
Ignoring faults and repeatedly resetting without fixing the cause is what leads to real damage.
The VFD is protecting your investment.
Practical Checklist Before Contacting Support
Before assuming a hardware issue, check:
  • Is the VFD on a dedicated circuit?
  • Are other machines starting at the same time?
  • Are you using an extension cord?
  • Is the wire gauge appropriate?
  • Is the input voltage stable under load?
  • Are acceleration and deceleration times reasonable?
Solving these issues prevents most VFD-related faults entirely.
Final Thought
Most VFD errors are not signs of a bad spindle or a bad drive. They are signs of a system doing exactly what it was designed to do.
Good power equals a calm VFD.
Poor power equals protection mode.
If you’re unsure about your setup, reach out. We’re happy to help you diagnose power quality issues before they turn into downtime.
