Home > Spindles & ATCs > E. First Power On & Operation > Operating Instructions for PwnCNC Spindle Systems
Whether you're installing a new spindle system or maintaining one already in use, these instructions will guide you through safe startup, daily operation, and maintenance of your PwnCNC air-cooled or water-cooled spindle β€” including compatibility with VFDs and ATC configurations.
This article applies to:
  • 1.5kW & 2.2kW air-cooled and water-cooled spindles
  • ATC (automatic tool changer) spindle systems
  • Standard Delixi EM61 VFD-controlled setups
βœ… Before You Begin: Safety & Power Prep
Electrical Warnings:
  • Spindles are powered by high-voltage 3-phase AC output from a VFD.
  • Never wire a spindle directly to AC wall power.
  • Always disconnect power before servicing or wiring your spindle or VFD.
Basic Requirements:
  • Use a properly rated VFD (Delixi EM61 or similar, 1.5kW–2.2kW)
  • Connect to VFD using shielded spindle cable
  • VFD should be fused or breaker protected on the AC input side
πŸ”Œ Initial Setup & Break-In
Before cutting anything, perform a spindle break-in procedure to distribute bearing grease and stabilize startup behavior.
πŸ”§ Follow the spindle break-in guide β†’
Break-in ensures:
  • Even lubrication distribution
  • Reduced bearing squeal
  • Extended spindle lifespan
🟒 Basic Operation
1. Power On Sequence
  • Power on your VFD first
  • Wait 4-6 seconds for self-check
  • Send a spindle command via M3 (forward) or M4 (reverse) with an S-speed value (e.g. M3 S12000)
  • Spindle ramps up smoothly over 6–20Β seconds depending on VFD settings
2. Speed Control
  • RPM is controlled via:
    • Software command (Sxxxxx in G-code)
    • Manual potentiometer (via keypad)
    • PWM-to-analog voltage conversion from controller
πŸ’‘ Most PwnCNC setups use 0.10–10.00V analog input from a controller (Masso, GRBL, etc.)
πŸ”§ Guide to adjusting VFD analog input settings β†’
πŸ”„ Direction Control
  • M3 = Forward (normal rotation for cutting)
  • M4 = Reverse
  • M5 = Stop
Reversing direction is only used for specific operations (e.g., tapping or retracting ATC tools). Avoid changing direction while spindle is still spinning.
⚠️ Important Safety Reminders
  • Never start the spindle with a tool loosely seated
    Always check the collet and nut tightness before powering on.
  • Avoid sudden RPM changes under load
    Ramp speeds slowly via VFD acceleration settings.
  • Do not exceed rated RPM
    Most of our spindles are rated for 24,000 RPM. Exceeding this risks bearing damage.
  • Coolant (for water-cooled spindles)
    Use clean distilled water + coolant or RV antifreeze mix. Never use tap water.
🧼 Maintenance Schedule
Task Frequency
Check collet & nut tightness Daily
Clean spindle exterior Weekly
Check cable strain relief Monthly
Flush & replace water coolant Every 3–6 months
Listen for bearing noise or vibration Ongoing
πŸ“Ž Downloads & Support Resources
Β
⚠️ Safety Notice:
Always disconnect power and air supply before servicing. Follow all safety precautions. PwnCNC products are intended for skilled users building or operating hobbyist to light industrial CNC systems.
πŸ’¬ Still Need Help?
If you're unsure about spindle performance, VFD tuning, or suspect an issue with your setup, contact our support team β†’. We’ll help you troubleshoot quickly and safely.
