Home > Spindles & ATCs > A. Start Here > 3. What Is a VFD, and Why Do You Need One?
A Variable Frequency Drive (VFD) converts standard wall power (AC) into a controlled, variable-frequency output that drives a three-phase spindle motor.
Unlike a router that runs at a fixed speed, a spindle requires a VFD to:
  • Start and stop safely
  • Control speed accurately
  • Deliver torque across a wide RPM range
  • Integrate with CNC software or hardware controls
Without a VFD, a CNC spindle cannot be operated safely or correctly.
What a VFD Provides
A properly configured VFD allows you to:
  • Adjust spindle speed from near zero up to 24,000 RPM
  • Control acceleration and deceleration smoothly
  • Protect the motor from overload and overheating
  • Detect electrical faults before damage occurs
  • Control the spindle remotely through your CNC controller
In short, the VFD is not just a power source, it is an active protection and control system.
The PwnCNC-Recommended VFD: Delixi EM61
After testing and supporting multiple options, we standardized on the Delixi EM61 series VFD for hobby and semi-professional CNC machines.
We support EM61 models configured for:
  • 110V and 220V input power
  • 1.5kW and 2.2kW spindles
  • Air-cooled and water-cooled motors
Why We Chose the EM61
  • Compact and clean physical design
  • Stable performance across a wide load range
  • Works well with GRBL, Masso, and other controllers
  • Excellent thermal management
  • Strong internal protection systems
  • Reliable availability and long-term support
This is the VFD we use in our own systems and design our documentation around.
Final Thought
A VFD-driven spindle is one of the biggest upgrades you can make to a CNC machine. When configured correctly, it delivers quieter operation, better control, and longer component life.
