⚙️ ATC Motor Mounting Position
When installing your ATC spindle motor, follow this simple method to ensure proper alignment:
Lower the Z-axis completely until it reaches the bottom of its travel.
Place the motor into the mount, allowing it to rest securely on the machine bed.
Tighten the spindle mount to lock the motor in place.
Raise the Z-axis back up once the motor is secured.
Once the motor is mounted, you're ready to program your ATC system in Masso.
