Home > Dominator CNC > Conversion Kit > Drag Chains and Cable Management for CNC Conversions
When upgrading a CNC machine with a conversion kit, spindle, or additional accessories, cable management becomes a critical part of reliability, not just aesthetics.
Many CNC machines ship with drag chains sized only for their original wiring. Once you introduce shielded stepper cables, spindle wiring, probes, tool setters, or future upgrades, those chains often become undersized.
This article explains when and why to upgrade drag chains, and how to do it correctly.
Why Drag Chain Size Matters
Undersized or overloaded drag chains are a common source of long-term issues, including:
  • Intermittent motor alarms
  • Cable fatigue and internal conductor breaks
  • EMI and noise-related faults
  • Premature cable failure inside the chain
  • Difficult troubleshooting weeks or months after install
Even if everything works on day one, tight bend radii and cable compression inside chains can create latent failures.
Recommended Chain Size for Conversions
For most CNC conversions, we recommend 18×50 drag chains as a baseline.
This size provides:
  • Adequate clearance for multiple shielded cables
  • Proper bend radius for stepper and spindle wiring
  • Room for future expansion without reworking cable routing
  • Reduced stress on connectors and ferrules
This is the same size we use across our own machines and conversion installs.
Mounting Considerations
Most machines were not originally designed to accept larger drag chains. In many cases, this requires:
  • Adapter brackets
  • Spacers
  • Offset mounts
  • Custom or 3D printed solutions
The key goal is simple:
  • The chain must articulate freely
  • Cables must not rub or pinch at either end
  • The chain must not be forced into a tighter bend radius than designed
A slightly oversized chain is always better than one that is too small.
Cable Routing Best Practices
When routing cables through drag chains:
  • Leave a small service loop at each end
  • Do not pull cables tight inside the chain
  • Avoid stacking cables tightly on top of each other
  • Keep spindle power cables separated from signal and encoder lines when possible
  • Ensure shield drains exit the chain cleanly and are grounded properly
Proper routing here directly improves noise immunity and system longevity.
Planning for the Future
Even if your current setup seems simple, it’s smart to plan drag chains with future upgrades in mind, such as:
  • Spindle or VFD upgrades
  • Probes or tool setters
  • Rotary axes
  • ATC wiring
  • Additional sensors or accessories
Rebuilding drag chains later is far more disruptive than doing it right during the initial conversion.
Final Thoughts
Drag chains are often treated as an afterthought, but in CNC conversions they are a reliability component.
If you’re upgrading electronics, motors, or spindles, upgrading cable management at the same time will save time, reduce troubleshooting, and protect your investment long-term.
If you’re unsure whether your current chains are adequate, or want guidance on sizing and routing, reach out to support and we’ll help you evaluate your setup.
Shapeoko_5_Pro_Bigger_Cable_Chains.zip
